Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-26-2006, 08:34 PM
ebpd10 ebpd10 is offline
loss of power
I have a 1998 cvpi. when i am driving down the road it feels like it stalls but does not always stall. the red temp light flashes and it feels almost like it is not getting gas. i am getting a code of p0112. when the car is stopped and running it will stall everyonce in a while. Anyone have any ideas.
Old 06-26-2006, 09:01 PM
reekor reekor is offline
Re: loss of power
Check the connection at the intake air temperature sensor, if all is good replace it.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 06-27-2006, 06:35 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: loss of power
This may sound funny, but also check all the coils. We have had 5 of these do the same thing, but they would die also. Would crank over but not start until the key was turned off and back on. The primary windings in the coils were shorting out allowing secondary voltage to go the the PCM and screw with it. If you have a scan tool, hook it up and see if you lose communication with PCM when problem occurs.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-27-2006, 12:36 PM
Re: loss of power
I replaced the IAT sensor but it did not change anything. i will check the the coils.
Old 06-27-2006, 07:27 PM
Re: loss of power
Do you still get the p0112 code?
Old 06-28-2006, 08:05 PM
Re: loss of power
still getting p0112 code
