Old 06-26-2006, 07:41 PM
TheBrettster TheBrettster is offline
AF Premium User
Flowmaster
I'm trading my stock exhaust for a FlowMaster, is this a good thing to do and is flowmaster a good replacement.
2001 Chevrolet Blazer 4.3
Old 06-26-2006, 08:15 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Flowmaster
they sound good but don't flow very well.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 06-26-2006, 08:17 PM
AF Premium User
Re: Flowmaster
well is it better than my stock POS with dent in it?
Old 06-26-2006, 09:19 PM
Eslhockey92g's Avatar
Eslhockey92g Eslhockey92g is offline
Re: Flowmaster
http://www.automotiveforums.com/vbul...d.php?t=571572
look at that, my 40 series flow master w/ side exit soudns awesome i think. If i find a ravin i may to the switch though
Old 06-26-2006, 09:22 PM
98BlackTransAm's Avatar
98BlackTransAm 98BlackTransAm is offline
Send a message via AIM to 98BlackTransAm
Re: Flowmaster
flowmaster's a noticeable sound/performance upgrade over stock (assuming cat-back) but there are better performance set ups out there.
2002 Firehawk (M6) http://www.youtube.com/watch?v=6XKnrV7c_Bs
F13 cam (230/232, .595/.585, 112+4 LSA) | PRC Dual Valve Springs | LS2 Timing Chain | Ported LS6 oil pump | Pacesetter LT's | TSP catted y-pipe | Flowtech cutout | LS6 intake | SLP lid | SLP cat-back | Bilstein suspension | Tuned by Mayhem Motorsports
1998 Pontiac Trans Am (A4) - SOLD
slp lid, pacesetter lts, ory, flowtech cutout, fuddle 3400 stall, B&M tranny cooler
Old 06-26-2006, 10:03 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Flowmaster
Go with a cherry Bomb Vortex.
They bought out Ravin's design and are practically the same thing.
Don't go with flowmaster, it won't do anything but drone.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-27-2006, 06:16 AM
DetroitMuscle's Avatar
DetroitMuscle DetroitMuscle is offline
Send a message via AIM to DetroitMuscle Send a message via Yahoo to DetroitMuscle
Re: Flowmaster
The only things that flowmasters actually live up to is their sound. Especially on f bodies, they flow less then stock.
Old 06-27-2006, 09:06 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: Flowmaster
But the Cherry bomb Vortex Classic. or V-Baffle???
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 06-27-2006, 09:15 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Flowmaster
V baffle - the FloPro, Ravin and some Flowmasters use the semi-triangular velocity baffle inside the body tube of the muffler to make it's dstinctive tone.
Old 06-27-2006, 09:58 AM
Re: Flowmaster
Nice. I need to do an exhaust soon.
K&N Air Filter
Old 06-27-2006, 11:49 AM
ZL1power69's Avatar
GM S-Series Mod
Re: Flowmaster
cherry bombs flow good but kill ur gas mileage
Low 11 sec sleeper
My Cardomain
Old 06-27-2006, 01:39 PM
Re: Flowmaster
how does a better flowing muffler hurt your mpg? doen't decrease in back pressure = increase in mpg?
Old 06-27-2006, 02:04 PM
wolfox's Avatar
Re: Flowmaster
Decrease in backpressure too much on a 4.3 GM V-6 makes it operate a little wierd. It likes to have just the right amount still in order for proper EGR flow, O2 sensor feedback and allow the valve overlap from exhaust -> intake "stall" just a bit to help cool the exhaust valves from the natural scavenging that occurs with the draw created when the exhaust pulse streams down and through the collectors. Mess with this fine balance a little too much and the ECU doesn't know what to think on top of the *possibility* that you start damaging heads and exhaust valves with elevated temperatures. Further modification with headers/collectors usually means swapping all of that with new heads and valves that are hardened for the task. An ECM flash is also required to compensate for the new flow parameters and interpret fuel injection signals from MAP/MAF & O2 sensors. This is not to say it will not work, but I am one to err on the side of caution a little and upgrade *everything* in the path that is affected in this manner.
A FloPro is the most free flowing of them all, however, in our application the most I would venture to put on the truck would be a 750 with center inlet, offset outlet. (2.25" dimater tubes) This is bbout as close as you can get to the absolute edge without harming anything else; flow better than stock and save some dough while doing it. It maintains a token amount of backpressure so heads/valves stay cool, EGR does it's trick, O2 is metered properly and the ECU stays happy without tossing codes. And that's my . I got an immediate 11% gain in MPG with my muffler setup before I opened up and modded the intake to match it.
Old 06-27-2006, 02:09 PM
Re: Flowmaster
ah gotcha,, yea I dont really kno much about the 4.3 v6's
Old 06-27-2006, 02:13 PM
wolfox's Avatar
Re: Flowmaster
It's cool man, it's what we're all here for - to lean. It's all about exhaust velocities and the effect they have on head flow. If you let all of that energy pass without restriction, intake air/fuel mixture will not "dwell" or linger around and through the exhaust ports long enough for effective surface -> air heat transfer. That's the big killer. Everything else is curable with a proper ECM flash or Memcal update in the older rigs, like mine.
EDIT: Gotta remember, these left the factory as reliable, rock steady truck engines that run happily on regular pump gas. They generate great torque at sedate engine speeds, and though pressed, not really meant for continuous high speed operation. If you're going for a little more performance, the bolt on stuff works to a point. After you breech that point, time to think of complete engine mods, swapping stuff out of the bay or what some adventurous folks do - swap for the infamous small block V-8's and build them up to speed and power.
I turned a relatively tourqey, gas guzzling Ram 1500 into a decent street racer once, but it took all sorts of tricks in addition to just plain cat-back and intake mods to get it right. Dropped the dough to get matched flow injectors, beefier volume fuel pump, the performance DCM (and three different flashes until it ran right on pump premium fuel), cam, rear-end gearing, tranny toughening and enhanced cooling in to handle the increased engine output. Luckily, Dodge didn't make too much distinction between factory built engines and thier A-block crates making powerful, small block v-8 mods really easy. I was about to rebuild the entire bottom end of the crank and rods to really toughen things up some, but ended up selling off the truck for $7,500 more than I originally paid to cover a really rough spont in my life. I still miss that truck. *sniff* I'm content with my Blazer though, and try as I might - getting formidable power out of it is going to take considerable work and a few friend's favors that hve garages I can borow on weekends to get it all done right.
