Old 06-25-2006, 03:03 PM
quinch2005 quinch2005 is offline
98 gtp will not start sometimes
I had this problem before and I thought I fixed. Sometimes I goto start the
car and all I get is all the lights and instrument panel working as usual
and a small noise that may be my fuel pump priming but the engine does not turn over or any thing. I don't have a security sytem with my key. I took my steering column apart and don't have a conector to put a resistor across.
I used a test light from the thick yellow wire under the ignition switch
when the car wouldn't start and found I had no voltage on that wire and was told to test that wire. So I replaced the starter and for a mounth I had no problem than the problem came back. Can astarter go bad that quickly
PLEASE HELP
Old 06-25-2006, 03:25 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 98 gtp will not start sometimes
I'm a little confused. Does the engine crank when ignition is taken to start? If the starter isn't doing anything check the 12 volts at the "S" input which is to the starter solenoid. If missing back track to the ignition/crank relay and then the ignition switch.
On the starter, was it OEM/GM or aftermarket?
Timeslip 08/12/06
AF Community Guidelines
Old 06-25-2006, 03:26 PM
maxwedge maxwedge is offline
A990 racer
Pretty sure you have the vats in that car, chip in key, does the security lite stay on? Also check for 12v at the purple ? wire at the solenoid when the key is in the crank position.
Old 06-26-2006, 11:24 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
In addition to above suggestions, try starting it in neutral (if you don't have power at the s-terminal on the solenoid) instead of park. Your neutral safety switch may be bad in the park position.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-26-2006, 04:24 PM
A990 racer
Thumbs up Re: 98 gtp will not start sometimes
Good one Rich, didn't think of the prndl.
Old 06-26-2006, 04:28 PM
I was told that the yellow wire was to the solenoid !
I bought the starter on line at autowarehouse.com
Old 06-26-2006, 05:27 PM
BNaylor's Avatar
The color coding may be different so do not depend on that.
Basically, there are two wires of concern going to starter. One smaller one that goes to the starter solenoid and the bigger black or red one that is starter B+ which is hot at all times since it is just about connected directly to the battery.
To check solenoid 12 volts input the ignition switch must be held to start.
BTW - The proper term for the park/neutral switch mentioned is Transmission Range Switch.
Timeslip 08/12/06
Old 06-26-2006, 07:05 PM
A990 racer
Cool Re: 98 gtp will not start sometimes
Come on Bob, everyone knows it's " prindle".
Old 06-26-2006, 07:57 PM
BNaylor's Avatar
I like Pringles. Pretty tasty.
All I understand or know when it comes to trannies are: A833, A727, TorqueFlite, M21, M22, <--Rockcrusher, TH350 or TH400, etc.
Timeslip 08/12/06
Old 06-27-2006, 12:29 PM
richtazz's Avatar
I try using common terms, PRNDL switch and transmission range switch are newer terms not all people recognize. I agree with you Bob, The older trans were so much simpler. These newer tranny's are some sort of voodoo science as far as I'm concerned.
