Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 08-02-2002, 08:58 PM
HedsIc HedsIc is offline
89 Sable PROBLEMS.... PLEASE HELP
I am having problems with a friends 89 Sable. it will not start what so ever. the starte kicks over just find but no start. the Fuel puump works just fine you can tell it's working just rigth but no matter what the car won't start. just turns over but no starting. if anyone can help me with what this might be and what to do to fix it PLEASE DO
Old 10-17-2003, 02:31 PM
Lparty Lparty is offline
You are the third person I know that has a Mercury Sable that just won't start. My father and a friend of mine are both having problems with their Mercury Sable. The car only starts when it wants to. When trying to start you can hear the fuel pump. They checked the starter, no problem. It's not overheating. Every time my fathers neighbor (who is a mechanic) comes to look at the car it, the car will start. He said he can't check it out unless it doesn't start.
Old 10-22-2003, 08:12 AM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
Sounds like the TFI module on the distributor, in both cases. This troublesome part has not been one of Ford's better ideas.
Old 10-24-2003, 09:50 PM
tazman tazman is offline
Re: 89 Sable PROBLEMS.... PLEASE HELP
I had an '89 Sable Wagon with the same problem and never get it start again. Two mechanics came over to my house and couldn't fix it either. We did try the distributor, wires, cap, rotor, plugs, etc... I finally had it towed to the junk yard after nearly a year of working on the car. I tried the dealerships in my area and was told there was nothing they could do about it. They didn't know how to fix it either. I haven't bought another Ford product since.
Old 10-24-2003, 09:58 PM
Even the stealerships didn't want to take a run at it?!
I've got an '87 Taurus wagon, and have learned a LOT about these cars.
They ain't THAT tough to fix... It's a simple electrical problem.
Old 11-06-2003, 09:17 PM
The 2 mechanics who came over were from the Ford dealership. When I pulled the car to another dealer he said he couldn't figure it out either. The tried various electrical components and even ran the lines back with no luck. All it would do is turn over but never start. We put a lot of hours working on that beast over the course of the year and just finally threw in the towel. I've been working on cars for over 20yrs. and have never failed at getting them running until this one.
Old 12-14-2003, 09:47 AM
[email protected] jjgsix@aol.com is offline
Make sure the wires leaving the battery are plug in and that the fuseable liinks if any are not burned out (use an ohm meter).
Old 07-24-2004, 09:01 PM
deejaydan deejaydan is offline
Had this problem with my wife's car. Turned out to be the fuel pump. Starter turned the engine over just fine. Had spark at the plugs. Even had fuel in the rail. Just not enough pressure (30-40 pounds!). Replaced the pump (in tank of course) and runs fine.
Old 08-08-2004, 06:17 PM
thinkink thinkink is offline
Just Curious!?
If it's a "simple" electrical problem? And you are an expert!? Why didn't you give the person something "specific" to go on!?
By declaring "They ain't THAT tough to fix... It's a simple electrical problem." is just a wee bit inspecific, isn't it?
But to your credit, you've narrowed it down to about 50% of the total possible aspects of the makeup of any vehicle.
2003 Sable transmission problem please help! 03Merc Sable 6 12-17-2007 06:19 PM
02 Mercury Sable Heating/Cooling Problem Please Help NebulaD Taurus | Taurus Wagon 5 07-13-2007 01:11 PM
Dash and transmission problem. Electrical or Ignition Switch problem? Please help ! bdybldr2 Silverado 1 03-01-2007 06:13 PM
Problems, problems - please help Im6ft9 Monte Carlo 4 06-20-2006 12:19 PM
2003 Cavalier Starting Problem--PLEASE help. Please? AriadneRaynor Cavalier Problem Diagnosis 8 03-01-2005 08:18 PM
