Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 06-16-2006, 12:27 AM
4RUNNER_RIDER 4RUNNER_RIDER is offline
Electrical Wire
Anyone here have done replacing there stock audio deck to a newer deck? I have some question and some wire that I am not familier with, the 2 wire that goes to the actuator and I trace it all the way to the deck were it connect to, after removing my stock deck and wonder if I really need to connect those 2 wire? it is the yellow wire and the black wire and what does the actuator actually do? the actuator is locate under the engine compartment were it connect to the throttle, if anyone know wiring around the deck area pls give information what I will need to do cause some wire are not connect to some speaker were I don't know what it is, thanks alot!
92' 4RUNNER V6
Old 06-16-2006, 01:39 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Electrical Wire
Check out the information on this site:
http://www.installdr.com/
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 06-16-2006, 02:19 AM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
Re: Electrical Wire
I can send you your wirring diagrams for the audio harnesses and connectors.
I have six pages that pertain to the audio system in the 92 4Runner.
I sent you a private message respond to my email address I gave you and I will send them to you.
