Old 06-15-2006, 10:49 AM
mickbench's Avatar
mickbench mickbench is offline
Suitable putty for resin..??
What is a good putty for use with Resin, I was thinking standard Revel or Tamiya putty, or must I use a resin type putty? Someone said you can make your own using CA glue and sanding dust, but CA glue is hard, and resin is soft, so I want something that sands and blends better this using CA glue and resin dust etc…
Also, does Tamiya primer adhere well to resin? Or would I be better of using an automotive based lacquer primer? I know you can use any type of primer, I’m just looking for confirmations that’s all. I was considering using the primer decanted from the can through my airbrush, but if I do this, I might just buy some standard bottle automotive primer instead, or would Tamiya primer be a bit thinner and more suitable for resin? I don’t want the paint to lift off, so I want it to adhere as soon as I start to apply TS white, I don’t want it to peel or flake off from the slightest touch..
Thanks all..
Old 06-15-2006, 10:55 AM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
Re: Suitable putty for resin..??
I see people use tamiya's putty on resin kits
Old 06-15-2006, 11:27 AM
freakray freakray is offline
AF Modelrater
Super glue with an accelerant works great in my experience.
AF User Guidelines
Old 06-15-2006, 11:59 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
I'll second that, superglue works well.
Not all resins are the same either. I just did a couple BBR Ferrari's and the resin was so hard it was almost the same hardness as superglue. While hard and brittle, it made it easy to work with a filler of the same density.
Other brands of resin I've worked with are very soft, but with care super glue can still be used with great results, and it feather edges well. Just use it sparingly so only have to do a minimum of sanding... - Mark
Old 06-15-2006, 04:53 PM
ZTony8 ZTony8 is offline
I've used plain old Testor's putty on resin bodies and have had no problems.My projects tend to sit a while before I sand them so that may be a partial explanation.I've wondered if some of the same chemicals in that are in the resins used in models because they smell similar.
Tony Buglione
Old 06-15-2006, 05:13 PM
Cold_Fire Cold_Fire is offline
Vendor
Try mixing dense cyanoacrylate with some talc powder and use that as putty. It works really great when you take some practice and experience with the mix. It dries fast as hell and it gets nearly the same density as plastic, you can sand it very susccesfully.
Old 06-16-2006, 06:26 AM
mighty_real's Avatar
mighty_real mighty_real is offline
I've used both Evercoat EuroSoft putty and Tamiya primer on resin with no issues at all.
John
Old 06-16-2006, 01:48 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
i use tamiya putty with no issues so far, i just give it extra drying time.
olly olly oxen free
