Old 06-12-2006, 08:07 PM
Carfreak18's Avatar
Carfreak18 Carfreak18 is offline
Send a message via AIM to Carfreak18
04' grand am jacking points
Hola, Does anyone know where I can find the jacking points for this type of car?...or do most cars have standards jacking points?..
Holland Speedway
Lake Erie Speedway
Tioga Speedway (R.I.P)
Wyoming County Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Many more to come....
Old 06-12-2006, 08:59 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: 04' grand am jacking points
Your owner's manual will tell you. Usually there are notches in the pinchwelds of the rocker panel sheetmetal; right behind the front wheels and right in front of the rear wheels.
Dragging people kicking and screaming into the enlightenment.
Old 06-14-2006, 07:58 PM
Gearhead202 Gearhead202 is offline
these points are designed for the jack provided with the car for changing a tire they can be used and will be fine for non-frequent use. but if u are constantly jacking the vehicle with a floor jack try to find a more solid point the pinchwelds can fold and "squish" with time and constant jacking but they can be used. that is what they are there for.
Old 06-14-2006, 10:34 PM
Carfreak18's Avatar
Im stilll confused where the pinchwelds are?
Holland Speedway
Lake Erie Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Old 06-14-2006, 11:41 PM
curtis73's Avatar
Lay down on the ground beside the drivers door. Its where the pretty painted part under the door meets the floor panel of the car. The panel under the door disappears under the car. Then it flares down and is welded to the floor panel. Behind the front wheel and in front of the rear wheel there should be notches in the pinchweld for the factory jack. I agree that using a regular floor jack will flatten the pinch welds, but that is the only factory approved place to lift since its a unibody car.
Old 06-15-2006, 10:20 AM
Carfreak18's Avatar
Thanks, Ill take a look
Holland Speedway
Lake Erie Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Old 06-15-2006, 08:43 PM
Damn sorry forgot about that unibody thing ya jack it on the pinch welds
