Old 06-11-2006, 10:26 AM
RK4332 RK4332 is offline
Airbag code 35
Anyone know what the problem could be? The bags, and ecs were replaced, and it gave me a code 35. Just put a new clock spring in, and still have it.
Old 06-11-2006, 11:07 AM
TaurusKing TaurusKing is offline
Re: Airbag code 35
35 is low resistance in the passenger-side airbag,, either a short in the wiring or resistance issues in the airbag module.. were the codes erased after repair?? I'm thinking maybe hard faults can't be erased, only by successive key starts with no further issues, I may be wrong on this...
Old 06-11-2006, 12:15 PM
Re: Airbag code 35
I cant find any shorts, and all the wiring seems to be fine, as far as i can trace it. I guess i should have mentioned, this is a 1999 Taurus. Is it possible that i was sold the wrong airbags? Even though they plugged right in, and fit right in.
Old 06-11-2006, 10:54 PM
Re: Airbag code 35
Possibly everything could be alright, still the code may be there until the required number of keystarts with no further faults, I'm thinking over 200+ keystarts are required.. maybe another on here has further info, I'm not 100% on this... you could always have someone experienced with airbag systems run a check as defined by that code, or do it yourself if you understand the inherent dangers of working with airbags.. why were the airbags replaced???Was the car a wrecker??
Old 06-12-2006, 06:44 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Airbag code 35
The air bag codes can be erased with a scanner that is capable of reading the air bag sensors. It is a simple process, but you need access to the proper tool.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
