Old 07-31-2002, 12:28 AM
CRX586's Avatar
CRX586 CRX586 is offline
reverse lights stopped working, please help
My reverse lights stopped working this week...
1. Tried replacing the bulbs (although I really didn't think that was the problem since they both went out at the same time).
2. Tried replacing the fuse (I didn't think this was the problem either - same fuse for the turn signals, which work fine).
So any ideas where my problem is? I'm guessing some wires came loose...?
Old 07-31-2002, 12:31 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Get a Chiltons manual and try looking up the diagram and see where the wires are routed.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-31-2002, 12:33 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I imagine that it's a bad connection some where. Get a volt-meter and test the wiring at various points to see wether you're getting a voltage across them.
Old 08-01-2002, 12:53 AM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
There are 2 wires that usually hang or sit on your tranny just under the distributor...you cant interchange em, male and female...they are for the back up lights. Also, check above the left shock tower (driverside), there should be a round plug with maybe 9 wires plugged to it...the one in the bottom (red) is the back up lights...check these 2 first and see if they're loose or something...:flash:
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 08-01-2002, 02:52 AM
CRX586's Avatar
Thanks for the help, I'll check it this weekend...
Old 08-01-2002, 03:28 AM
habib_88's Avatar
habib_88 habib_88 is offline
Question
I think the tranny as plug that goes into it, its actaully the reverse switch. It shouldn't be to hard to find i think i remeber running into the one on my tranny before. Check the connections on it, or maybe you just need a new switch?
89 Si #77 and now with 2003 STS winnAr mod!
LadyNRedSi: the integra is a spotless cow
habibswd: i'd sooooo milk a spotless cow
...wow that was a old conversation
Old 08-01-2002, 06:10 AM
7PSICRX's Avatar
7PSICRX 7PSICRX is offline
The reverse light switch is located on the top of the transmission, just behind the distributor I believe.
Here's a little trick that might work, it did for me.
If it has a washer, remove it.
If it does not have a washer, add one.
While you have the switch out, plug the wires back in, turn the ignition on, and depress the plunger to see if the switch itself is working.
98 Regal GS headlights and fog lights stop working *PLEASE READ* tremayne0126 Regal 2 06-09-2010 10:03 AM
help... wipers wont stop working please help rottweilers999 Yukon 7 03-07-2008 04:56 PM
My wipers just stopped working.....PLEASE HELP!!! officer629 Probe 0 09-10-2004 09:32 PM
Rear Reverse Lights stopped working Jeeped Cherokee 3 09-01-2004 07:56 PM
shift light wont work please help!!! B16Civic93 Let's get Technical! 2 07-08-2004 12:59 AM
