Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 06-05-2006, 12:15 PM
kool7 kool7 is offline
Smile Help: 97' 4runner VEHICLE SPEED SENSOR Help
My 97' 4 runner failed its emission inspection due to a failed On Board Diagnostic Code. The code was identified as "P1700 - Manufacturer Controlled Transmission". Does anyone know what this code referrs to and is it something that I might be able to repair? Or is this something to let a Toyota Service Center handle?
thank you very much for your help and reply..... joe
2WD, V6 ,SR5 ... AUTO TRANS ...
Old 06-09-2006, 06:58 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Help:97' 4runner Check Engine Code P1700
It is likely that you have a bad Vehicle Speed Sensor or bad circuit (loose connection or bad wiring).
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 06-11-2006, 12:10 AM
Re: Help:97' 4runner VEHICLE SPEED SENSOR
Hi, Thanks for the info. .
My repair book tells me to check the resistance across the sensor leads.
what is the correct resistance range for this test ..
thanks all .................
