Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-28-2002, 02:25 PM
Eclipse99 Eclipse99 is offline
Send a message via AIM to Eclipse99
engine mods
My 99 eclipse is a non-turbo. I'm going to do exhaust, headers and intake for sure. What other mods do you suggest to increase hp without endangering the life of the car (i.e. ruining the transmission, etc.).
Old 07-29-2002, 09:01 PM
BlkSprk's Avatar
BlkSprk BlkSprk is offline
best bet is a turbo, spark plugs, new wires, an msd ignition(or someother aftermarket ignition), aftermarket radiator, new cams, new cam gears. I would avoid Nitrous if i were you, unless you wanna fully upgrade your engine, including connecting rods, piston heads, valves and all the likes. i hope this helps some.
:ylsuper
-BlkSprk
Old 08-06-2002, 11:36 AM
jdoug jdoug is offline
Send a message via Yahoo to jdoug
Well, while adding a turbo will certainly increase horsepower, it would be a substantial investment ($3-4K). Decide now how far you want to go, modifications-wise, to determine whether it would be better to just trade your car in for a turbo model and go from there.
J Doug
Old 08-09-2002, 01:59 AM
ECTurboGSX ECTurboGSX is offline
Send a message via AIM to ECTurboGSX
:ylsuper
-BlkSprk
Power adders all have the same effect. You can run a 50 shot without worrying too much, in the same manner that you can run 7 psi on the turbo kit. Go over a 50 shot and things start going bang. Go over 7 psi, and things start going bang. In order to make max power with a power adder, you will have to rebuild with new rods, pistons, studs and bolts, clutch, and probably rework the crank. Having the supporting mods is the key.
Eric
1990 Mitsu Eclipse GSX
13.4 @ 102.9
Big 16G @ 19 psi
S14 engine mods and body kits Kerpalstaxi 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 10 03-02-2003 02:00 AM
Engine Mods MODS94 Engineering/ Technical 3 07-18-2002 02:37 PM
Engine Mods Whiplash9001 Cavalier 1 03-28-2002 02:21 PM
Starting engine mods--where do I start? eclipseproject Engine, Transmission and Drivetrain 5 03-13-2002 08:48 PM
Engine Mods for a Turbo or Supercharger? hiphopsk8er27 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 02-05-2002 06:20 PM
