Old 02-05-2002, 12:10 PM
hiphopsk8er27 hiphopsk8er27 is offline
Engine Mods for a Turbo or Supercharger?
I have a 1997 Honda Civic EX. Im looking into buying a turbo or supercharger. What would be my best choice? What engine modifications should i perform so my engine can hadle the power? What are the prices i'll be looking at?..Help me please!
Old 02-05-2002, 12:22 PM
kidrocket kidrocket is offline
Send a message via AIM to kidrocket
depending on how you go about it youll be spending upwards of 3 grand
Old 02-05-2002, 12:23 PM
Si2000 Vtec Si2000 Vtec is offline
Send a message via AIM to Si2000 Vtec
Many aftermarket turbochargers and superchargers are designed to work on your stock engine internals. However, swapping out pistons, valvetrain, etc. allows for more boost which means way more power for you! One of the most crutial aspects of forced induction is unimpeded airflow... the more restrictive your airflow, the less power. So, cat-backs make much more difference on a FI engine rather than a NA. Same with air filters. Where as you'd get like 2hp from a nice filter with an NA engine, you'd get 10 with a FI.
In a nutshell, it's way easier to make power when your working with forced induction. Cost efficiency goes through the roof... the hard part is saving the money for the turbo/sc.
Old 02-05-2002, 12:24 PM
Thanks for the price range....but i still need to know what modifications i must make so i can handle the power for that amount of money. Not just for the super/turbo charger but onther mods to the engine as well.
Old 02-05-2002, 12:27 PM
How much is it gonna cost for new pistons and drivetrains, etc with installation?
Old 02-05-2002, 12:35 PM
Are you rich or something? Hehe.
It's usually done in steps. Your first step would obviously be to purchase a forced induction system.
Second, your going to want to get it installed =) Like my simple steps?
You can run 5-6psi safely on your stock motor, so you'll be fine with an extra 35hp for a while. Then when you can afford more stuff (low compression pistons, fuel system, etc), start purchasing those items. I'm sure you can pick up a set of pistons for around $300 with rings, but you'll end up paying upwards of $300 for install also.
The best thing you can do is set a plan for yourself. Pace yourself and do things in steps. Talk to some local speedshops and pick their brains about forced induction, and what steps you should take to eventually raise your boost.
Old 02-05-2002, 12:47 PM
What do you suggest for a forced induction system?
Old 02-05-2002, 12:54 PM
Depends on what you want. For Honda's, my thoughts are for course/autox get a supercharger, for drag get a turbo. I'm building my car mostly for drag, but since its a daily driver, I might opt for the supercharger. But for now, I'm building the car all-motor (easier to build as you get money).
Old 02-05-2002, 01:07 PM
When I buy a turbocharger kit, am i going to need to mount the intercooler on the front or will i have room under the hood?
Old 02-05-2002, 01:21 PM
Depends on the kit you buy. MOST aftermarket kits (Greddy, Drag, etc.) have front-mount kits, which are much more efficient at cooling air. Unless you are planning on doing a WRX hood-conversion , mount your intercooler in your front.
Old 02-05-2002, 02:07 PM
TriCkCiViC97 TriCkCiViC97 is offline
Isn't the front mounted intercooler likely to get all dinged up and ruined by reflected stones, etc.?
Old 02-05-2002, 05:20 PM
Can somebody please answer hiphop's question?!?!?!...I really need to know as well...Thanks :smoker2:
will engine mods for then LS coupe work for the LS sedan? ruffio1842 Integra 4 01-20-2006 03:11 PM
engine mods for turbo or supercharger beef_bourito Forced Induction 11 06-02-2004 02:25 AM
engine modded for turbo? gearsforbrains RX-7 3 02-24-2004 04:07 PM
engine mods for 3.8 woowoo316 Thunderbird 0 07-28-2003 11:29 PM
Civic dx engine mod for cheap civic91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 07-10-2002 06:12 PM
