Old 07-28-2002, 12:50 PM
Mr Mario's Avatar
Mr Mario Mr Mario is offline
Unhappy Newbie help on polishing
I have used the search menu to look for help on this topic.
But none of them answer my question I think?
I have the Tamiya Polishing compound and here is my questions?
1. Can I put some polishing compound on my body(car) after the clear coat was put on?
2. Do I have to wet sand the body after the clear coat was put on then apply the polishing compund?
3. Will the polising compund remove some paint?
I am using Tamiya Acrylic paints on my model.
Any help would be great.
Thanks
Old 07-28-2002, 01:06 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
I don't know if this applies to models, but in real life clearcoat makes paint imperfections more visible. I assume you would remove as much orange peel by sanding with 2000+ grit sandpaper and then polishing it down, then applying clearcoat after its smooth as glass. And then I suppose you can polish the clearcoat to give the whole model a clean finish.
I've never experienced with tamiya polish, but turtle wax polishing compound seems to work fine for me.
Old 07-29-2002, 12:01 PM
Jacobs40K Jacobs40K is offline
Send a message via AIM to Jacobs40K
polishing steps
It isn't necessary to add clearcoat if you polish the paint directly.
you can polish the clearcoat tho if you have laid one down.
get a nice set of sanding cloths: 4000-12000 grit.
I try to use only 6000 and above to get rid of orange peel. i usually wet sand to save wear on the sanding cloths.
after you sand with the 12000 grit, you will have a decent shine already, but then you start with the waxes. there is a 4 step process that well worth the money that you spend on the wax.
1. use Meguiars #2 - it is a fine scratch remover
2. use Meguiars #9 - swirl remover
3. use Meguiars #7 - polishing wax
4. finish with Meguiars #26 - liquid not paste
this works great with lacquers too.
Jake
Old 07-29-2002, 12:30 PM
Mr Mario's Avatar
Great thanks for the advice!
I'll try that
Old 07-29-2002, 03:30 PM
Wthermans's Avatar
Wthermans Wthermans is offline
Send a message via AIM to Wthermans
I've looked all over town for some high grit polishing cloths. Anyone know where I can get some online?
1998 Contour SVT E0 Silver Frost
#3623 of 6535 Car B-day:09/18/97
My 98 CSVT
Currently working on: Tamiya Porsche 911 GT3
"Life is full of conflicts; it's the moments of peace we must cherish"-me
Old 07-29-2002, 05:37 PM
modelfan1's Avatar
modelfan1 modelfan1 is offline
Send a message via AIM to modelfan1 Send a message via Yahoo to modelfan1
Micro-Surface has all the polishing cloths anyone will need online !
:bandit: Mike
Old age and treachery will overcome youthful exuberance everytime !!
Old 07-29-2002, 06:01 PM
daggerlee's Avatar
One thing you have to be wary of is cure time for the paints. Generally wait 10 days after spraying for enamels, and 4 days after lacquers (assuming you keep them in 60-70 degree or above weather). Otherwise the paint is too soft and does not respond well to polishing.
Im a newbie, help me out Shariq E-Class 6 09-20-2009 12:30 PM
Polished Valve Cover for sale Axelthered05 Classifieds 0 06-22-2009 02:09 PM
newbie help...88 lincoln towncar signature series help mterrien420 Town Car 6 01-10-2008 06:03 AM
Mitsu Newbie Help PLEASE!!! ShockJon Lancer 1 09-26-2002 09:05 PM
Newbie Help zohar Mustang Talk 0 05-05-2002 06:08 PM
