Old 07-28-2002, 12:14 AM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Check engine light, HELP!!!
I have had this check engine light problem for a couple of month;s now and I am getting no where trying to resolve the problems. My 92 Prelude SI is pulling a code for throttle position. I see the problem. The clamp with the wires is loose. Does anyone know if this can be fixed. I have looked in numerous junk yards and they only sell the wiring harness with the engines. I just need that one clip to stay in. Any help would be appreciated. Also I am pulling an O2 sensor code. Trying to get this fixed because I have to pass emissions.
Old 08-09-2002, 06:58 AM
Shawn D Shawn D is offline
Send a message via AIM to Shawn D
take the clip apart and solder to the actual pins...could be risky but otherwise you dont really have a choice other than picking up a new plug from honda or the junk yard.
Old 08-11-2002, 01:50 AM
b16a3sol b16a3sol is offline
sounds to me like you just need to replace parts, but you dont want to. if you are pulling a code for O2, then i would say replace the sensor. if you are pulling a code for TPS, then replace that part also. if you cant get it from a junkyard without buying a motor, then try the dealership. i am certain they will sell you what you need, rather than a whole motor.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
