Old 05-26-2006, 03:34 PM
NewyorkKopter's Avatar
NewyorkKopter NewyorkKopter is offline
Enzo Side Intakes
Hey, I can't figure out what all the intake on the Enzo are for. Could somebody please tell me what those huge upper and small lower side intakes are for?
Old 05-26-2006, 05:08 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Enzo Side Intakes
Upper is probably for engine cooling or air intake, lower one is for brake cooling.
Dragging people kicking and screaming into the enlightenment.
Old 05-26-2006, 05:21 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
To make it mo' purdy.
Old 05-26-2006, 05:32 PM
hehe yea. As for the intakes, thats what i was thinking, that the upper is for the engine intake, but that changed when I saw this picture
In the upper right, you see how the huge scoop is bringing air to that radiator or cooler thats mounted right on the wheel arch? Its the one with the steel braided lines. So yea, that would mean the lower intake would have to be for the engine, but then again, could a 660 hp V12 breathe through those small intakes?
Old 05-26-2006, 08:33 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
I think the big one's for a radiator and an intake. if you look at the top of the engine, you can see the intake leading to just in front of the radiator. I'd be willing to guess that they're taking intake air in and passing the rest through the radiator.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 05-27-2006, 08:20 AM
yea I guess so because Ferrari did something similar with the F50. You, know how the F50 only has two lateral ducts in front of the rear wheels?
Look at this pic
Its the same thing, there's a radiator placed infront of the intake, and the engine intake box is just over the radiator. But wouldn't that cause the F50's V12 to suck in hot ambient air? As for the Enzo wouldn't letting the air pass from the intake get rid of some of the ram air effect?
Old 05-27-2006, 03:06 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
you can see where the airboxes are, those top ones probably feed both the airboxes and the two oil coolers, the radiators are front mounted. i'd imagine the lower ducts are for brake cooling.
Seatbelts Saved My Life
Old 05-28-2006, 07:42 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
That is by far and away the best answer in the thread.
Old 05-28-2006, 08:13 PM
lol, yea they probably divided the upper intakes to give air to the air intake boxes and the smaller coolers as well. But the F50 im just lost. Because in that drawing the radiator's taking up the whole opening, and a 500 hp V12 can't breathe by sucking in ambient air from the engine bay
Old 05-29-2006, 02:47 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
The front two intakes are to cool the radiator and the top two side intakes are for the engine's air intake alone, and the bottom two side intakes are for brake cooling.
Old 05-29-2006, 05:38 PM
amanichen amanichen is offline
Originally Posted by NewyorkKopter
... could a 660 hp V12 breathe through those small intakes?
Looking at the area of the McLaren F1's intake, the answer is probably yes.
For an even more direct comparison, look at the Maserati MC12.
Old 05-29-2006, 05:58 PM
munna munna is offline
Front and back bottom ones are for brakes. big side ones are air intakes and flow to raidiators.
cheers
Nissan Skyline
R33 GTS25T - Full 3" Exhaust, SAFC2, Hybrid intercooler, 10.5psi boost.
195.7 rwkw
Old 05-29-2006, 09:19 PM
oo, because then thats the only way it makes sense. The huge upper intakes are for those smaller radiators, while the smaller lower intakes are ironically for the engine. But then again the McLaren's intake is a ram air intake placed on the roof, where there's tons of high pressure air flowing in to it. Because air going over the top of a car travels faster than it travels under the car. So maybe Ferrari found a way create a similar effect on the lower sides of the car in order to supply the engine with adequate air .As for the brake cooling, Ferrari probably did the same thing with the rear brakes as they did with the front, they used ducts mounted directly on the knuckle that would scoop the air from under the car to the rotors. But the F50, I have no clue where that car gets its air for the engine fom. Also, here's a pic of the Enzo's front brake ducting
About the MC12, From looking at the engine it seems as though its getting air from 3 intakes. The snorkel, and those two intakes that are right above the huge side intakes (you can see them on the far left and right in the pic), and those two intakes look about the same size as the Enzo's lower side intakes. So Im guessing that the MC12 also uses the huge side ones for smaller radiators, while using the other two smaller ones for the engine, and since its meant to be a racing car, they probably threw in a third intake, that snorkel on top to force even more air into the engine.
