Old 05-24-2006, 01:18 PM
79Bandit's Avatar
79Bandit 79Bandit is offline
best/quickest way to clean corrosion of battery cables?
title says it all
Old 05-24-2006, 01:25 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: best/quickest way to clean corrosion of battery cables?
If they're corroded, they probably have some white acid buildup on them.
To remove, make a wet paste of baking soda and water. Apply carefully or with something you can throw away later. Let it bubble awhile, add a little water, then rinse with more water. Repeat until it doesn't bubble. You might want to consider replacing the cables if they're badly corroded, as this method might not get all the acid that's within the strands of the cable.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 05-24-2006, 01:46 PM
thecackster's Avatar
thecackster thecackster is offline
Send a message via MSN to thecackster
What I would say exactly. With my experences the easiest way to do it with out another headache later.
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
Old 05-24-2006, 02:01 PM
79Bandit's Avatar
wow i have never heard of that way...lol i have been wire brushing the danm thing for the past hour....finally got it cranked again thanks..
Old 05-24-2006, 02:41 PM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Coca-Cola for about 5 minutes, then a wire terminal cleaner. Ain't had a problem since.
Old 05-24-2006, 09:51 PM
Mr Wiggl3s Mr Wiggl3s is offline
Banned
Send a message via AIM to Mr Wiggl3s
Ya, they got those nifty wire battery cleaners, ive heard the coca-cola before, and ive heard the baking powder works
Old 05-24-2006, 10:53 PM
Andydg Andydg is offline
That's always worked very well for me too.
Old 05-24-2006, 10:59 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
sandpaper and wire brush.
Seatbelts Saved My Life
Old 05-24-2006, 11:10 PM
Damien's Avatar
Damien Damien is offline
Send a message via AIM to Damien Send a message via MSN to Damien
any heavily carbonated soda man. Easy way. Heck, I've had people say their car want start and i got a can of coke, poured it on and a connection was bad.
only, they bought the coke, no me.
Old 05-25-2006, 08:23 AM
Cola will clean just about anything, I've used it to loosen rusted bolts.
Problem with using it on battery terminals/cables is that it's acidic also, so you're adding acid to acid which in the long run can make the corrosion problem worse. The baking soda neutralizes the acid.
But using Coke(tm) on battery terminals, guess the corrosive properties would help take off any non-metals that were there, which would enhance conductivity.
Old 05-26-2006, 08:25 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Ooh, ooh!!! I just watched MythBusters yesterday, and they were doing Coca-Cola myths... they used Coke to try cleaning battery terminals as well as water... and they were about the same in their cleaning properties.
Of all the things Coke was tested to do, it cleaned a chrome bumper (when used in conjunction with aluminum foil) even better than their store-bought chrome polish!!!
Sorry, I am stuck at home sick in this GORGEOUS spring weather and had nothing better to do than post.
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 05-27-2006, 03:23 AM
Whumbachumba's Avatar
Whumbachumba Whumbachumba is offline
I used Diet Coke, and it cleaned it off really well. We don't have regular coke in this house, and when we do buy regular sodas, it's Dr. Pepper.
Current Project: '70.5 Camaro; Air-Cooled GB: '66 Beetle; Shelby 427 Cobra
Old 05-29-2006, 01:11 AM
publicenemy137's Avatar
publicenemy137 publicenemy137 is offline
Send a message via MSN to publicenemy137
I just used a wire brush and some battery terminal cleaner. cleaned it up good. I actually had two cars with this problem at the same time, and my friend just told me about it a week earlier so I found out what it was to fix it.
Old 05-29-2006, 01:24 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Boiling hot water poored over the terminals, then some Petroleum Jelly smeared around them to stop the build up re-occuring.
Works better than anything else, Iv done it doozens of times.
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
They make a spray on chemical just for this kind of thing, I've got a can in my garage.
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
