Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 07-26-2002, 12:41 AM
stefan525 stefan525 is offline
Send a message via AIM to stefan525
Prelude ??? clutch???
I have a friend that has a 1988 Prelude Si, he had the clutch insatlled by the dealer and he still has problems with it. It will work fine for the first 5-10min when is cold and then when it gets hot and you put it in gear and it seems like it has no power, and it will barelly go. I have no idea what it could be. This is his second clutch and pressure plate. Please help. Thanks Stefan525.
Old 07-31-2002, 11:58 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
sounds like a bum clutch. take it to someone you can trust.
Old 07-31-2002, 10:14 PM
cybercrx00 cybercrx00 is offline
Send a message via AIM to cybercrx00 Send a message via Yahoo to cybercrx00
either a bum clutch, or it may need to be readjusted when it is hot, might not be engaging with full pressure
Old 07-31-2002, 11:05 PM
Well, it is a brand new clutch and the first one was done by honda dealer and it still did the same thing. And is hydraulic so there is nothing to adjust, unless there is something I don't know about. Anyway if there is anything else you guys can tell me I would verry much appreciate that. Thanks so much. stefan525
Old 08-06-2002, 02:01 AM
MARKUSIUDIUS MARKUSIUDIUS is offline
Might be
Check the clutch pedal and also the outter box to see if there is any signs of fluid leaking. You may also have a bum master and slave cylinder. I recently replaced both of mine and the clutch was still slipping it only needed a little more adjustment.
:flash:
1994 2.2lt Jap import Vtec, Blown with a 1GGZE charger 300Hp or 220+kw
Malpassi Reg, 500 injector, Unichip piggyback management system, Top gun leads, Map controller, Vtec controller, Custom FM Cooler, Custom fast flow exhaust and weight reduced (2640pds)
90 prelude clutch slave cylinder install sprat Prelude 3 06-16-2008 05:48 PM
88-89 Prelude clutch options? sofast Prelude 0 10-09-2004 08:52 PM
88 prelude clutch problems fentruck Prelude 6 03-01-2004 11:03 AM
