Old 05-16-2006, 08:35 AM
f4istunter f4istunter is offline
Question: front wheel bearings
hey
first time posting
just got a 97 gt for 500CAN.
but i get this humming sound from the front left side and know its the wheel bearing but u guys always talk about buying a new hub when in previous cars i had u can just knock out the bearing and use the same hub., and simply pound in the new one
as i dont have tons of money as i just put on a new waterpump yesterday(85can) id liek to just get the bearing itself and swap it out
let me know if this is duable
Old 05-16-2006, 08:56 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Question: front wheel bearings
The hub & bearing is all one piece so you cannot do just the bearing.
Plus there is an ABS wheel sensor integrated in.
Timeslip 08/12/06
AF Community Guidelines
Old 05-16-2006, 08:58 AM
thanks, anyone know where to find one for the best price?
2001 GP GT
1997 GP GT (Parts Car)
Old 05-16-2006, 09:11 AM
gprixgtp gprixgtp is offline
Best quality or best priced? There is a big difference. If you do not go with Delco, then make sure you get either a BCA(Federal Mogal) or a CR bearing assembly. Do not I repeat do not get a white box or an Autozone special. You will be doing it twice.
Old 05-16-2006, 09:19 AM
ok so got sum prices
179CAN for the cheap one im guessing, or 279CAN(for better one) at UAP
and i got 329CAN at Canadian tire......
guess im gonna wait till it blows out till i fix it lol
2001 GP GT
Old 05-16-2006, 09:21 AM
mabye ill try the wreckers and try to find one with little or no kilometers on it
i could prolly walk out paying 30 bucks for one
one more quikc thing, will i have to do an allingment after i swap the hub?
2001 GP GT
Old 05-16-2006, 09:46 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I wourk for a Delco distributor in Flint, MI, and I can get you a delco for $151 (US dollars)+ s/h. I assume you are in Canada, so if you PM me with your Canadian postal code, I can get you a shipping quote.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-16-2006, 09:48 AM
BNaylor's Avatar
Boneyard is a good idea but since you are up North rust will be a problem.
Probably not. I never did but it probably won't hurt on the alignment.
Timeslip 08/12/06
Old 05-16-2006, 02:53 PM
wlkjr's Avatar
wlkjr wlkjr is offline
Richtazz has the best deal on AC Delcos.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 05-18-2006, 02:58 PM
Ok got one for 60 bucks fron the wreckers off a 99 gt with 45k(k not miles)
the gave me the hole spindle and i got a puller but its ment to be used with the spindle on the car(center bolt pushs on the drive axel to push it out) but now theres nothing to push on,, Any sugestions on how i can remove this hub from spindle
thanks
2001 GP GT
Old 05-19-2006, 10:35 AM
wlkjr's Avatar
thanks
I'm confused, but I used a 3 jaw puller to get mine off.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 05-19-2006, 07:02 PM
hey
well end result was..... just put the whole spindle on, only took like 45 min to do. hardest part was prying down with a pole on the control arm to drop the lower ball joint out of spindle.. other then that it was easy
2001 GP GT
