Old 07-22-2002, 07:36 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Need some information regarding spark plugs.
I just changed my spark plugs from a set of Bosch Platinum’s to a set of NGK Iridium IX spark plugs. Under hard acceleration the car would misfire with the Bosch plugs in. This is why I bought the NGK, I have heard they are the best and last the longest. However; when I pulled the Bosch plugs nothing really looks wrong, I was expecting them to be burnt. Instead there are two with a white corrosion on the tips, I forget what that means. Could someone rectify that for me? Also if the damn thing keeps misfiring what could be the problem? What causes misfires besides burnt plugs? I know that having to large of a gap with too weak of an ignition system can cause this in older cars. Do anybody in here know the answers to my questions?
Thanks in advance ~ Polygon
Old 07-22-2002, 08:35 PM
454Casull 454Casull is offline
White spark plugs mean overheating. Here's what I found on a site...
* Incorrect spark plug (too hot heat range).
* Low octane fuel.
* Timing is not set properly.
* Cooling problems, (dirty cylinder fins, no or low water if water cooled, low or no engine oil).
* Carburetor air/fuel mixture is too lean.
* Leaking crankshaft seals, no oil, base or head gasket leaks, or crankcase leaks on two stroke engines.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
Hello again...need some help with spark plug wire order for 1.8L SOHC smbius Off-Topic 2 04-18-2005 01:47 AM
Need some information about Whipple Superchargers YukonSS Yukon 0 10-30-2003 12:42 AM
need some information ( Tracks ) eric gonzalez Drifting 3 10-17-2003 08:07 AM
