Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-11-2006, 05:48 AM
NitrousFreak27 NitrousFreak27 is offline
Rusted/Cracked Strut Tower
Hey. On my Talon the front right strut tower has rust and cracking from a right side hit and was wondering how I would repair this. Its about a fingers width and you could actually slide your finger across it for 3-4 inches. You can actually stick ur finger in there. Here is a pick of what Im trying to say but Ill get actual pics later.
http://pic19.picturetrail.com/VOL102.../145878900.jpg
The passenger strut tower, the blue area is all rusted and cracked and you can stick your finger in it. Would welding fix this and how would this effect me? Would it now be a good time to buy a front strut? Thanks.
Old 05-11-2006, 08:29 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: Rusted/Cracked Strut Tower
Bondo?
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 05-11-2006, 08:55 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
That car in the pic was luscious....
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 05-11-2006, 05:23 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
I think you can replace that whole stut tower area. If I'm correct EZ did it on his 2ga gsx. But as far as trying to fix or patch up the damaged part I wouldn't suggest that.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 05-11-2006, 07:10 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
You want to grind it down and see how extensive the rust is. When i bought my car the strut had broken through. You should try to do this as soon as possible because you could ruin your hood and possibly cause an acident. Here's a pic of what my car looked like. You can replace the entire part which goes from the front umper to the firewall, it's $250 from th dealer i can get you the part number if you want
http://img490.imageshack.us/my.php?image=gsex0020px.jpg
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-11-2006, 08:16 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
thats an impressive picture, shitty situation though.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 05-11-2006, 10:44 PM
ez1286's Avatar
Here's some after shost and also a diagram of the part s avalible in tht spot.
http://img393.imageshack.us/my.php?i...ixed0012nq.jpg
http://img393.imageshack.us/my.php?i...ixed0027rh.jpg
http://img190.imageshack.us/my.php?image=caps9sd.jpg
Old 05-12-2006, 05:25 AM
How is the install? Did you do it yourself or have a shop? Also, did you just go to any Mitsubishi dealer and order the part? Thanks
Old 05-12-2006, 07:20 AM
ez1286's Avatar
Well i did it myself but i have a welder and air tools (mostly an air chissel) It wasn't that bad kind of just fit into place. Don't get me wrong it took some time but it wasn't all that bad.
Old 04-30-2013, 08:30 PM
ShadeTreeJack ShadeTreeJack is offline
I had this problem on my 2001 Eclipse GT.
http://img829.imageshack.us/img829/4476/03091317481.jpg
I bought a spot weld cutter and an air chisel. I had a welder. there are a lot more spot welds than you think..
I found the replacement at jnztuning.com about $200 including shipping
http://img843.imageshack.us/img843/6787/dsc0001xa.jpg
http://img826.imageshack.us/img826/7890/dsc0004bg.jpg
