Go Back   Automotive Forums Car Chat > Jeep > Wrangler
View Poll Results: what can you tell me
give 0 0%
receive 0 0%
Voters: 0. You may not vote on this poll
Old 05-10-2006, 10:27 PM
page1 page1 is offline
Question jeep lift
I was wondering if 33's will fit on a 95 yj with a three inch add a leaf lift with no problems and i was also wondering what my oil pressure should be reading?
Old 05-15-2006, 11:42 AM
wilson05's Avatar
wilson05 wilson05 is offline
Send a message via ICQ to wilson05
Re: jeep lift
the 33's should fit if its atleast a 3 inch lift like you say but you have to account for heavy thing like whether you have a hard top or heavy bumpers ... but yeah if it did raise it 3 inches then you should be fine... probably a little rub while turning at max turn .... other than that the oil pressure should read a little over half sorry i cant remember the numbers exactly
Old 05-15-2006, 11:59 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: jeep lift
Lots of discussion about lift and tires is here:
http://www.automotiveforums.com/vbul...d.php?t=387657
As far as oil pressure, mine runs about 40 (center of gauge) at idle and about 55psi on the road, 2000 4.0 with 90K. On our 2004 2.4 Liter, it's about the same.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 05-16-2006, 11:18 AM
mudcrazed mudcrazed is offline
Re: jeep lift
If you have the original springs on that 95, you should re-consider going with the add-a-leaf. I don't think there is anyway you'll actually see a 3 inch lift with an add-a-leaf kit on springs that are 11 years old.
And I think you're pushing it with 33 inch tires with a 3" lift. If you're going to wheel it, you'll have some significant rubbing. You'd be much netter off going with a 4 inch lift to handle those tires.
Old 05-23-2006, 10:32 AM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Re: jeep lift
I've never owned a Jeep with leaf springs, but can't you relocate the axle to underneath the spring instead of over to get a good amount of lift... then some small leaf lift? I think I saw that on SpikeTV.
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
Old 05-30-2006, 05:40 PM
Re: jeep lift
That's a spring over axle kit and it is not for the less initiated to attempt. There are a number of complications which usually arrise and need to be worked out!
