Old 05-09-2006, 08:18 AM
handyandyap handyandyap is offline
Oil light with AC on
Hi,
I have a 94 Taurus with a 3.0L. I just noticed that the oil light comes on when the AC is on. The light only comes on when the car is at idle. Any suggestions would be helpfull. Thanks, Andy (UPDATE) I noticed the oil light flash on and off a little today at an idle without the AC on. Is this a sign that my oil pump is going out?
Old 05-09-2006, 12:32 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Oil light with AC on
Does the engine rpm's drop when the a/c is turned on? If so the low engine speed is causing the light to come on. The engine is not turning enough rpm's to pressurize the oil sending unit. I would look to the idle speed control.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 05-09-2006, 06:09 PM
I noticed the oil light flash on and off a little today at an idle without the AC on. Is this a sign that my oil pump is going out? Thanks, Andy
Old 05-09-2006, 06:28 PM
way2old's Avatar
TOKEN HILLBILLY
Not necessarily. You need to hook up a mechanical gauge to get the true oil pressure of the engine. If oil pressure stays in specs with the mechanical gauge, then the sending unit is at fault. If the gauge is lower than specs, the oil pump pick up screen could be partially clogged, the oil pump could be starting to wear out of tolerances. Oh, by the way, is the oil level full?
Old 05-09-2006, 07:35 PM
brokenantimatter brokenantimatter is offline
Engine type?
RPM range at neutral?
PRM range at neutral with AC on?
RPM range at first gear?
RPM range at first gear with AC on?
RPM range at third gear?
RPM range at third gear with AC on?
RPM range at top gear?
RPM range at top gear with AC on?
Anyways you could be facing a couple of things:
  • Insufficient Engine Power
  • Low Oil Level
  • Poor Oil Quality
  • Faulty Oil Pump
  • Clogged Oil Pump
  • To Much play in the drive belt
Old 05-09-2006, 07:43 PM
Millermagic Millermagic is offline
Flickering light is fairly common with the vulcan engine in these cars. Aparently, ford didn't design the computer program to let the car idle fast enough.
