Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-03-2006, 04:33 PM
Tylrdurdan Tylrdurdan is offline
Exclamation Someone Please Help I am ready to shoot something
Ok had a problem awhile back.....alt was over charging the battery and acid was leaking out the posts. Renewed the alt and battery. Charging system is working great better than ever. But why are all the damn gauges still on for the dashboard?!?!?!?! Battery light, Water, Oil, every light you can think of its on. Is there a reason for this or am I just losing my mind. Someone told me that when i blew that alt that i could have fried the ignition switch or some type of component. Please Help.
Old 05-03-2006, 09:16 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Someone Please Help I am ready to shoot something
After you got everything hooked back up, how long before all the guages started lighting up? Did you try unhooking the battery for about 5 mins after that to reset everything and see if they came back?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 05-04-2006, 09:22 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
It sounds like a BCM problem we get with cars here at the shop, what year eclipse do you have?
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 05-04-2006, 04:47 PM
Its a 1995 GSX....but if it could be the BCM wouldn't it still throw a code or the check engine light? Also I had the battery disconnected for at least half a day. The battery light is on, but its very very dim. I am gonna check the belt to make sure its tight because i heard that if the belt isn't tight it would still throw the light on. But my main concern is the coolant light...both of them are on, no leaks, holding pressure, and its full.....this car is either going to be the death of me or its gonna take me broke. thanks for the help.
Old 05-05-2006, 01:01 AM
Don't quote me on this, but I think I remember somebody describing your problems and it ended up being the thermometer in the radiator that died and made everything go crazy with guages and whatnot. Something you can check anyway.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 05-05-2006, 01:04 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
yeah the temperature sensor going bad can set off some crazy shit.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-10-2006, 06:10 PM
Smile Re: Someone Please Help I am ready to shoot something
Just wanted to let you all know that it was the temp sensor. I never knew how screwed up that could be. thanks for all the help guys.
Old 05-10-2006, 06:13 PM
ez1286's Avatar
Cool, glad to hear it.
Old 05-10-2006, 06:54 PM
haha I rule.
'92 3000gt SL
Zoom Stage 1 Clutch
