Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-25-2006, 12:20 AM
Pac-Man_G Pac-Man_G is offline
Send a message via AIM to Pac-Man_G
Needing Help Fixing The Problem
hey, when i start to rev the motor at like 3g's and it want to die out. my friend says it the air to fuel ratio..but the question is how do i fix that? its a 94 cx with a D16z6 motor in it. i'm not sure if the fuel pump was chaged to handle the v-tec... got an ideas?
Old 04-25-2006, 07:43 AM
GEESERTEG's Avatar
GEESERTEG GEESERTEG is offline
Re: Needing Help Fixing The Problem
The ECU based on feedback will make the proper adjustments...sooo you have another problem. Have you checked for any CEL codes from the ECU?
http://www.HondaFactor.com ---- Honda/Acura Enthusiast Community
07 Habanero Red Civ Si -- baby's new baby.
94 Honda CivicEX -- 200,000mi ---SOLD
98 Acura Integra GSR --SSBP-- Tein H-techs/Tokico Blues/AEM SRI/More SOON
02 Fud Expedition 5.4 EB
Old 04-25-2006, 07:59 AM
Chromedubs165db Chromedubs165db is offline
It could be MANY things, but to start i would check the fuel filter.
Old 04-25-2006, 08:10 AM
GEESERTEG's Avatar
Very true... I got ahead of myself again...haha
Old 04-25-2006, 12:55 PM
fuel filter. now should i go with a stock honda fuel filter? or with an aftermarket one like AEM or something at autozone?
Old 04-25-2006, 02:39 PM
GEESERTEG's Avatar
Stock is fine
Old 04-26-2006, 12:03 AM
Originally Posted by GEESERTEG
Stock is fine
i chaged the stock fuel filter, but i also realized that it only happens when its a cold start when i just turn on the car it want to die out... if i rev the car up really high to the point it tops out it runs fine after that
Old 04-26-2006, 06:34 AM
GEESERTEG's Avatar
Have you checked for any ecu codes? How long has it been since you had a whole tune up? Plugs, wires, cap, rotor, airfilter
Old 04-26-2006, 03:24 PM
i'm not sure...but the guy i bought it from got a new distributer cap and wires i just changed the oil with 5-30w and new plugs a week ago
Old 04-27-2006, 11:34 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
What rpms does the engine idle at?
AF COMMUNITY GUIDELINES
Old 04-29-2006, 07:18 PM
i'm not to sure but i'm guessing just below a 1000 RPM i don't have a tachometer but when i rev it to about 2000RPM its wants to die out..but if i redline it a couple of times... and let it idle its fine...any ideas?
Old 04-29-2006, 08:48 PM
It sounds like you're starting to get clogged fuel injectors. Don't quote me on that one just yet. Is your check engine light (cel) on. If so you should go to autozone or advance auto and get them to check your codes. Usually they can tell you right there what the code is related too. If they can't then you can usually find the codes online. If your cel isn't on, I would run some fuel injector cleaner through the system and see if that helps dissolve the problem (no puns intended). If not then you need to check the pressure for the fuel system (it wouldn't hurt to go ahead and do that if you can) the only other cause that I can think of would be that your fuel pump is either going out or the fuel system is getting gummed up(possibly the pump).
Old 05-01-2006, 01:18 PM
my buddy said there's a couple of sencors on the intake for idle and choke responce....can that be a problem?
