Old 04-24-2006, 03:16 PM
cbjreutzel cbjreutzel is offline
Question '95 Grand Am -- Turn Key and Nothing
Something is seriously wrong with my car. 1995 Pontiac Grand Am. I put the key in and turn the ignition...eerie silence. Radio doesn't turn on, dome light doesn't turn on, nothing. I try a bunch of times, nothing. The electric locks still work though. Sit and wait in car, hear a clicking noise. Try again, starts up. The next day, the same thing! What is going on? Please help. Thanks.
Old 04-24-2006, 03:58 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: '95 Grand Am -- Turn Key and Nothing
Two things to check.
1- make sure the battery terminals are on tight. If they're not they'll provide enough trickle of juice to run things like locks and lights, but when you try to hit the starter it will act like a dead battery.
2- Where are the clicks coming from? If its an infrequent problem, your starter might be dying. Next time it happens give the starter a little whack with a wooden or rubber mallet. If it comes to life after that, its a bad starter.
3- Are you sure its just not a dead battery; either because its old or the alternator isn't charging?
Take it to a big chain parts store. They'll test it for free. They have a little meter that walks them through several steps to determine what is wrong with the electrical system.
Dragging people kicking and screaming into the enlightenment.
Old 04-24-2006, 04:02 PM
Hi. I should have stated that...we took the starter in and it was fine. Also have changed the battery out and it's not the problem. As for the click...it just sounds like it's coming from the dashboard I think. I've only heard it a couple of times, so I'll have to see if I can locate it. Any other information is greatly appreciated. Thanks!
Old 04-25-2006, 07:22 PM
travie5500 travie5500 is offline
well did you try to charge your battery?? maybee? that would help?
Old 04-25-2006, 07:42 PM
Wink Re: '95 Grand Am -- Turn Key and Nothing
The battery I changed it out to was in my husbands car and was charged just fine. Thanks.
