Old 07-16-2002, 12:35 AM
strodda strodda is offline
how to rewire system
i gotta simple little question for ya.
im gonna rewire everything tomorrow, is the power wire the only that needs to be separate from the rest?
Old 07-16-2002, 07:10 AM
93speed's Avatar
93speed 93speed is offline
Just make sure the power is separated from the RCA cable. I think the recommended is at least 12 in
Old 07-16-2002, 09:21 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
here we go again with the voodoo ..............
Old 07-17-2002, 12:57 AM
what else can cause interference? i rewired everything, put the 12v and rca on opposite sides of the car, but it didnt do a damn thing.
Old 07-17-2002, 02:52 AM
so-cali so-cali is offline
Im not sure if it would help your situation out at all but you could try and relocate the ground and the remote on the opposite side of the RCA as well.
In my car, i have the power and the remote running next to each other on the right side, the RCA runs down the middle, and the ground wire is grounded on the side.
I've had it like this for a while and i havent picked up any interference yet
1991 Acura Integra
Pioneer DEH-3400 Head Unit
Eclipse 82641 Speakers
4-ch 1000 watt Sony Amp
2 12" MTX 5000 subs/Bandpass Box
Old 07-17-2002, 02:58 AM
o, and just another thought... if your still picking up interference, you may have fried a wire... if you start running more power than your wiring can handle, you may have a problem.
My buddy bought some cheap wires to begin with and then after upgrading his stuff and adding a second amp (now running 2 1400w PPI's), he fried his 8 ga. power wire.
im not sure if everything would still work after frying a wire, but if you cant figure out what the problem is it might be worth looking into.
1991 Acura Integra
Old 07-17-2002, 08:46 AM
Audio Guy
I'll ask you guys the same question ..... when the stereo is not playing ANYTHING, just on, how much current do you you think is going thru that power wire - the answer is practically zero. So why is the engine noise contant in volume regardless of the volume of the stereo ?
P.S. if you still think it's from the power wire, consider that all that power coming thru the wire is returning to the battery thru the car chassis .... so if your theory were correct, it didn't matter WHERE you laid the RCA, every car would have noise.
P0410 Secondary Air Injection System shaundavis108 TrailBlazer | Trailblazer EXT 2 03-29-2010 07:36 PM
1995 325i Cooling system overheating troubleshooting kennethwperry 3 Series 0 09-20-2009 07:32 PM
Announcement of TOYOTA(Guangzhou) on Camry's braking system defect ChinaCamryUser Camry/Camry Hybrid/Vista 3 04-27-2009 11:54 PM
CAN (controller area network) or FlexRay systems? rnelson3 Engineering/ Technical 0 04-24-2009 10:27 AM
