Old 12-17-2009, 04:12 PM
shaundavis108 shaundavis108 is offline
P0410 Secondary Air Injection System
I had this code come up and im not sure what i need to fix, please help?
Old 12-18-2009, 10:54 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: P0410 Secondary Air Injection System
Welcome to AF
Always give year make and model and engine and mileage.
There is some info down in S-10 how to on that code.
First thing to check is fuses and wiring and hoses.
And clear code and see what comes back.
MT
Old 03-29-2010, 08:36 PM
JRolniak JRolniak is offline
I own a 2004 TB and had the same fault about 2 years ago. From searching online, I learned it was likely a check valve mounted on the passenger side of the engine. You need to listen for the air pump to come on for 4-5 seconds when you first turn the key to run (located underneath Trailblazer on driver's side around the area between both doors). I read it was common for this checkvalve to fail because of water collecting in the line. Some people had said their lines to the checkvalve were filled with water- mine had a slight amount of water dribble out. The checkvalve cost around $65 at the dealer if I recall correctly, and was fairly easy to replace.
Tags
air , injection , p0410 , secondary , system
