Old 04-11-2006, 03:29 PM
SkyDomain SkyDomain is offline
Plugged EGR Causes Problems
I plugged the EGR valve on my car with e Bosch LH-Jetronic 2.4 system, and it quickly detects this EGR flow error.
Is there a quick and easy way to fool the ECU so it thinks the flow is working as i would have?
Old 04-11-2006, 04:15 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Plugged EGR Causes Problems
Quick and easy would be to hook it back up. It doesnt really help or hurt performance.
Old 04-11-2006, 04:50 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Agreed. Without it you'll have detonation, increased NOx, and increased EGTs. EGR is a wonderful thing... keep it.
Dragging people kicking and screaming into the enlightenment.
Old 04-12-2006, 08:12 PM
boarder_punk's Avatar
boarder_punk boarder_punk is offline
Send a message via MSN to boarder_punk
Yeah, they are right, the EGR doesn't hurt performance like they did when they first came out. Modern engines are designed to run with the EGR so technically it helps your performance and fuel milage.
Old 04-15-2006, 07:53 PM
UncleBob UncleBob is offline
AF -Advisor
to answer the question, no there isn't any easy way to fool the computer.
Replace the entire engine management system with an aftermarket stand alone.....but that would be a bit more spendy that putting the EGR system back to stock config
