Old 04-06-2006, 08:51 PM
procrstinator procrstinator is offline
error codes
po303 ? maf or vaf ckt range/perf? i know what maf is but vaf?
Old 04-07-2006, 12:25 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: error codes
A Maf and Vaf are one and the same. However, the P0303 is not a MAF sensor DTC error code. It is a misfire detected on Cylinder #3.
You may need new spark plugs and/or wires or have a clogged/defective fuel injector on cylinder #3.
BTW - Stick with the AC Delco OEM Platinum or Iridium spark plugs to include ignition wires. Whatever you do, do not use Bosch spark plugs.
Timeslip 08/12/06
AF Community Guidelines
Old 04-07-2006, 09:16 AM
Re: error codes
yes i found out to late about the bosch plugs. ill take them out ty
Old 04-07-2006, 05:28 PM
vamc's Avatar
vamc vamc is offline
Re: error codes
Bob-your right on that one. Use ac delco. I used bosh o2 sencer once, and my car did not like it at all, then i used ac delco, works great. i like ac delco anyways.
Old 04-08-2006, 10:54 AM
BNaylor's Avatar
Re: error codes
Good choice Andrew.
Timeslip 08/12/06
Old 04-08-2006, 02:37 PM
vamc's Avatar
Re: error codes
I thought so! lol
