Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-03-2006, 01:26 AM
86CapMan 86CapMan is offline
front disc brake upgrade
Hi all,
It's been awhile since I have posted anything. Just read alot but I have a question I need help with...
Does anyone know if the front rotors from a 91 up Caprice can be used on a 1980-90 model? I want to go with larger rotors. I have 11" now and want to go with 12". Also if anyone know could I just use the rotors off a 80-90 wagon and do I also need the spindles?
Any help would be appreciated.
Old 04-03-2006, 01:39 AM
Blazin_Jason Blazin_Jason is offline
Re: front disc brake upgrade
I haven't done the upgrade to the 12's myself yet. From what I understand that you need the different spindles to allow for the caliper to mount properly.
Edit: About the rotors I don't know. This is for a wagon up till about 91: Front ; w/ 11 Rear Drum ; Overall Dia.: 301.5 ; Min Thick: 24.5 ; Height: 77.3. This is a newer caprice: Front ; w/ 4 Wheel Disc ; OE w/ Alloy Wheels ; Overall Dia.: 301.5 Min Thick: 24.5 ; Height: 118.1 *taken from carparts.com*
Now what I don't understand is the Height differences. They both have the same overall diameter but a different height? This was the same information I got at my local parts store. If anyone knows what is meant by "height" please let us know.
Jason
Old 04-03-2006, 10:33 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
You will need to do a spindle swap to be able to use the larger rotors, just as Blazin_Jason correctly stated. That's not all, either. The larger rotors will require different wheels as well - the smaller ones have a 5x4.75" bolt pattern with 7/16" studs, while the larger rotors have a 5x5" pattern with 1/2" studs.
1977-1990 B-body 9C1(generally) and wagon, as well as 1991-1996 All Models have the larger, 12" rotors with the 5x5" bolt pattern. 1977-1990 non-9C1(generally) sedans have the 5x4.75" pattern, however some 9C1s from this era may also be found with the 5x4.75" pattern (262 or 305 engines only).
The parts (spindles, springs, rotors, calipers etc) will interchange between 1977 and 1996.
"Height" is taken from the back of the rotor to the center of the hub on the front.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-03-2006, 11:48 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
im pretty sure you need the spindles to to mount the calipers
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 04-03-2006, 05:01 PM
http://www.globalwest.net/1964-72%20...informatio.htm
Use 12-inch rotors off a 1988-1992 1LE Camaro/Firebird GM part # GM 18016035. This is all you will need off the 88-92 Camaro/Firebird. If you want to keep the same 5 on 4.75 bolt pattern.
Silicon - Do you think that the 4cm difference between the 2 rotors would be a problem? Like if I used a pre 91 wagon spindle and these http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT rotors?
Old 04-03-2006, 08:30 PM
Hey thanks for the advice guys. I knew I could count on you. Asuming I go with the 12" rotor w/ 5 on 5 bolt pattern. Could I just get some rear axles from a 1991-96 Caprice/Impala and use those to keep 5on5 all around? Are the splines the same? Sounds like it would be best to get the 5 by 5 with the 1/2" studs considering this car is getting a stroker this year with a turbo 400.
Old 04-03-2006, 09:06 PM
CD Smalley CD Smalley is offline
Spline count is different. It changed in 88 or 89.
You might be better served to get the whole 89+ rearend....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
