Old 03-26-2006, 06:46 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Valve Tick
I've heard of valve tick in Eclipse's but how common is it in Civic's? I have a pretty loud click and I want to know if it could be a problem or if it's nothing to worry about? If it would help I can record it an post it.
AF COMMUNITY GUIDELINES
Old 03-28-2006, 12:14 AM
songsandstars's Avatar
songsandstars songsandstars is offline
Send a message via AIM to songsandstars
Re: Valve Tick
is it at only at startup and then goes away? is it a tick or a knock? give some more detail and i'll troubleshoot it.
Old 03-28-2006, 11:26 AM
Re: Valve Tick
It's a continious tick. It's obviously comming from the head. It sounds almost exactly like an Eclipse lifter tick. I'll post a link to a wave file later when I've had a chance to record it.
Old 03-28-2006, 01:58 PM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
Re: Valve Tick
sounds like its time to check your valve lash
ive got manuals
92-95 civic 96-98 Civic
clicky here clicky here
WTB:92-95 EX/SI cluster w/tach
FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers
Old 03-29-2006, 01:38 PM
Re: Valve Tick
Is there a post on checking that already and what should I be expecting to replace if worse comes to worse.
Here's some audio recordings of what my engine sounds like.
Idle
Engine Run
Old 03-29-2006, 06:28 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Valve Tick
sounds like a typical civic. injector cleaner and valve lash adjustment should fix it. i didnt hear any problems.
Old 03-29-2006, 11:19 PM
Re: Valve Tick
how difficult is the valve lash adjustment and do I need any special tools? I run 93 octane all the time. That's all i've put in it since the beginning of Dec.
Old 03-30-2006, 01:16 AM
Kind of a Big Deal
Re: Valve Tick
you need a set of valve lash feeler gauges. but you can get them at autozone. its pretty easy. good luck. and it never hurts to put some injector cleaner in your tank. (i found that valvoline works best)
Old 03-30-2006, 08:51 PM
Re: Valve Tick
idk why your running 93 octane but ,to do a valve lash just check my sig for instructions. there was a diy roaming around the net with pics the the pics have been deleted off that server. ill see if i can find another one.
ive got manuals
Old 03-31-2006, 12:37 AM
Re: Valve Tick
I'm running 93 octane because when I swap engines I'll be going turbo. This way I'm already used to paying for the gas.
