Old 03-25-2006, 09:38 PM
graphicassult's Avatar
graphicassult graphicassult is offline
Send a message via AIM to graphicassult Send a message via Yahoo to graphicassult
Need help, but no one ever has an answer
Ok, so i have a 99 GP GT, i love the thing to death.
Got it with valve cover leak, fixed it
And lately when i start it sometimes the car will shake...
Or when its warm out, around 40 or higher and the car is at operating temperatures the car will shake at a stop sign
Also sometimes when i'm hard on the throttle it will surge or feel a lack of power
I've asked around FOREVER and never got an answer...its like no one knows what it is doing
I've even taken it to 3 shops and they tell me they cant get it to do it.
And once I had an SES saying #3 Cylinder misfire, well the coil was new, new wires and plug was fine, so i replace the injector....
What should I do? Suggestions?
Thanks
"All right Ramblers, let's get ramblin."
Old 03-26-2006, 01:28 AM
GregA's Avatar
GregA GregA is offline
Re: Need help, but no one ever has an answer
Broken motor mount?
Just a guess though.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 03-26-2006, 08:53 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Do you see the engine physically moving or is it a misfire condition causing the shaking?
Are you stock or moded? If modded what are the mods? What is the mileage?
What brand/heat range spark plug and ignition wires did you put in?
How about the CAT convertor? Is it the original?
Timeslip 08/12/06
AF Community Guidelines
Old 03-26-2006, 12:27 PM
I have 111,000 on the motor. Only mod so far is a homemade ram air system which i'm switching to a FWI when it gets warm.
My plugs are AcDelco Iridiums, just what came in the car. I have Autolite Pro Series wires (i'm doubting those)
And As far as I know the cat is completly original. I'm hearing a little louder noise from the exhaust as of late, i think the mufflers are going on me
And as for seein the engine move, when i've looked I cant tell its really moving unless i place my hand on it
Old 03-26-2006, 12:47 PM
BNaylor's Avatar
Well, hopefully we can help get you squared away this time around.
If the Iridiums are 41-101 thats OK. Not sure about the Autolite plug wires. Our engine has a thing about using aftermarket wires such as Bosch, Autolite and others. Something about the resistance per foot. The best wires to use are the AC Delco Premium Silicone 7mm wires. They have the lowest resistance per foot and will handle an ignition system to well over 6500 rpms.
The CAT convertor can cause problems ranging from misfires/cutoff, poor fuel economy, a surging affect when accelerating and poor idle, etc. With your mileage and being the original it would be suspect. Best thing to do is get an exhaust system backpressure test which will test for a clogged or partially clogged CAT convertor. However, for the cost it would be cheaper just to get an aftermarket hi-flow like a Magnaflow and have it installed by a mom & pop muffler shop.
If the engine moves really bad that means you have a bad wishbone front mount(s), however, that would be quite obvious to the naked eye. A little flexing when watching and revving the engine is normal.
Other suggestion would be to clean the throttle body, especially the IAC sensor and seat with STP throttle body cleaner. Clean the inlet screen. Clean the MAF sensor hot wire element with electrical contact cleaner or spray MAF sensor cleaner. Make sure all the vacuum lines are good and tight.
From what I can see your engine shake is more like an ignition related misfire condition although it may not be triggering a SES light or any odb-ii DTC error code.
Timeslip 08/12/06
Old 03-26-2006, 12:49 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Hey graphicassult, hav you changed the fuel filter?
This might clear up your misfires or shaking of the motor. Thier can be subtle misfires that the SES wouldnt pick up on, caused by small particls in the fuel system.
Gm does recommend a fuel system flush(for $200 or so) at some interval, not exactly sure on the GP's interval, it wouldnt hurt to check in to it though.
1999 Grand Am SS 3.4 OHV
Old 03-26-2006, 03:46 PM
Filter has been changed and fuel system flush has been done.
I dont think its a misfire to be honest, It dosent handle like its misfiring....
However sometimes after a long drive when i Start the vehicle it shakes for a minute or so, and sometimes when I start it after sitting awhile it will shake a bit...
I think i'll goto my dealer and get AcDelco Wires and then get a new cat...
Old 03-26-2006, 04:12 PM
BNaylor's Avatar
Just to clarify on the shaking. Is the shaking there during cranking and before the engine fires up or when the engine has fired up and running? Or anything else you can clearly define. It is a weird problem.
Did you ever get the fuel pressure checked at the Schrader valve on the fuel pressure regulator to see if it is in specs?
Timeslip 08/12/06
Old 03-26-2006, 06:54 PM
The shaking is when the engine is running. I've never had it checked at the valve
Old 03-26-2006, 07:10 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
probably transmission
Old 03-26-2006, 09:12 PM
How Do you figure transmission?
Old 03-26-2006, 09:41 PM
Trans would make since. Just vibrations from internals turnnig.
My GA SE does some fucky stuff like that too after a long driv or after I've been doging it hard.
Mostly at stops in gear, is that what yours is doing?
Old 03-26-2006, 11:02 PM
bricker82's Avatar
bricker82 bricker82 is offline
I had the same problem with my 2000 GP, turned out to be a clogged cat converter at 77000 miles (thank god for the 8yr/80000 on those).
I only had the problem for about 2 days before I got it fixed, but it caused my number 2 & 4 coils to go (which caused the misfire) and my O2 sensor to throw a code.
Cat cost me nothing (except for a week's waiting because the cat was misshipped), but the rest of the stuff cost me about $300. Dealer said that if I'd got it down there sooner, it wouldn't have ruined the coils. I don't know about that, but whatever it's done!
Just my thoughts,
Brick
Old 03-27-2006, 12:55 AM
I've had a coil go out on me! I think this might be my fix, it would make sense.
Low rpm=little pressure where as high rpm=high pressure which is why i only feel it at low because theres not a lot of pressure to force through, and its the OEM cat....
Old 03-27-2006, 06:03 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Graphicassult, Advance AUto, if you have one in your area, sells Delco wire sets WAY cheaper than a dealer. If you don't have anyone in your area besides a dealer that sells them, I'll get you a price quote on them when I get to work (I work at an AC-Delco distributor in Flint, MI). PM me if you're interested with your Zip Code and I can get you an exact quote including shipping.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
