Old 03-25-2006, 04:18 PM
Camaro84 Camaro84 is offline
Exhaust pipes
Hey wassup everybody its been a while since i been on But Yeah im trying to seal my exhaust from the exhaust manifolds to my pipes and for some reason they are not sealing........ I went down to the chevy parts store and they said they dont sell the little donut gaskets for the pipes for 84 camaros... so i went to just put them on with out them........ but im getting all my exhaust smoke into my engine compartment....... can some one tell me what they think i should do.... thanks alot
Old 03-25-2006, 07:20 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: Exhaust pipes
You mean you tried to put your manifolds on without the gaskets?? Wow, that's definately not a bright idea. Try going to Advance Auto Parts/Autozone/NAPA and getting exhaust manifold gaskets for a 1984 Camaro, then they'll ask you what size engine and then you tell them.. Which btw, which engine do you have? If it's the 2.8L V6 then instead of telling them you have an 84 Camaro, tell them you have a 1988 Pontiac Fiero with a 2.8L V6. The gaskets for the Fiero are better designed than the one for the F-Body's.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 03-26-2006, 03:50 AM
Re: Exhaust pipes
Nooooooooo Thats not wat i did...... im Talking about when the exhaust manifold reaches the Pipes that gasket......
Old 03-26-2006, 05:54 PM
blindeyed's Avatar
eBay aDdict™
Re: Exhaust pipes
But.. there is no gasket that goes there. At least not on any 3rg gen Camaro I've ever seen. Normally it's just a one pipe that then ends with a 2 bolt pipe connector, then connects to the front end of the cat with the 2 bolts. 1 bolt on each side. Kinda like this:
http://www.ftpp.net/images/Bassani/b...socket_500.jpg
Are you able to take any pictures?
- Jason
Old 03-26-2006, 06:36 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
Re: Exhaust pipes
there is a donut gasket that goes there..your right......when i put mine back together i used the old one...and mine leaks a bit.not alot though...do you have the old ones?
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 03-26-2006, 06:46 PM
Re: Exhaust pipes
at the end of the manifold it looks like this
___
^^ is what the end of the manifold looks like....and the gasket goes on that ledge...the gasket is beveled on both sides
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 03-26-2006, 09:42 PM
blindeyed's Avatar
eBay aDdict™
Re: Exhaust pipes
hmm.. thats interesting... never knew that.
- Jason
