Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 07-08-2002, 08:10 AM
Turb Turb is offline
internal wastegates
is there a way to test the preset wastegate settings on an internal wastegate?
and how can i adjust it to raise or lessen the boost level?
don't have the funds yet to get a boost controller so it's out of the question for now.
thanks
Old 07-09-2002, 11:17 AM
Gonthrax's Avatar
Gonthrax Gonthrax is offline
Skyline Guy
Send a message via AIM to Gonthrax
Just make a bleed valve. Or buy one.
You need to run a hose from the wastegate actuator to the plenium chamber. The hose usually runs from the Wastegate actuator to in front of the turbo. Also you need a check valve to let air only flow one way through it.
Basicaly what you are doing is tricking the wastegate actuator into thinking you have less boost then you really do
Lemme know if you need better instructions.
Member of AF's Slide Squad (Member #04)
Originally posted by taranaki
Postcounts - Phoey....it's not how often you speak,it's whether you actually say anything that matters.
Neishlin Motors
Soon to be my best friend
Old 07-12-2002, 08:37 AM
bleed valve
so you mean instead of getting the boost signal from the compressor, the boost signal is now coming from the intake manifold?
i've read from corky bell's book that this is good if you want the best throttle response but the problem is there is more heat.
the bleed valve can increase the boost but how can i lessen the boost? does it depend on the original preset boost on the wastgate? then i should get an internal wastegate with a low preset boost and hook up a bleed valve to increase the boost? am i right or am i confusing you? hehe
guess i need better instructions too..
thanks!
Internal Wastegate to External wastegate fiberglasscivic N2O | Turbo | Superchargers 13 06-22-2006 12:34 AM
Turn T3 Turbo into Internal Wastegate? Lac-O-Power Engineering/ Technical 1 03-16-2004 11:45 AM
Can u turn a T3 non wastegate to internal wastegate Lac-O-Power '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 03-10-2004 02:58 PM
Changing Internal Wastegate ZeroG Forced Induction 0 02-07-2004 01:04 PM
Internal wastegate boost adjustment mrchris1979 Forced Induction 1 06-06-2003 08:46 AM
