Go Back   Automotive Forums Car Chat > Buick > Regal
Old 03-22-2006, 09:13 PM
bobbyfrazer bobbyfrazer is offline
micro switch location
my 95 buick regal has a broken shifter button and can be operated in any position without depressing it. also since this occured i cannot remove the key from the ignition. where are the micro switches and wires located so the ignition key may be removed ?
Old 03-23-2006, 11:16 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: micro switch location
All solenoids and switches are normally located with the shifter assembly if you have the center console. When in PARK 12v is sent to a key release solenoid located in the steering column, otherwise the key will stay stuck in the ignition switch.
Timeslip 08/12/06
AF Community Guidelines
Old 03-23-2006, 04:18 PM
thank you ! I'm no mechanic but learning. talk to you later. bobbyfrazer
