Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 03-18-2006, 11:42 PM
CRushER CRushER is offline
Send a message via AIM to CRushER Send a message via MSN to CRushER
Front End
I'm going to rebuild the front end suspension on my 71 nova. The thing only came with 6 control arm bushings, aren't they're suppose to be 8? I wasn't able to check all the components of the kit before I left the place after picking it up but I think I may have gotten shorted. Also what do strut rod bushings look like?
Old 03-20-2006, 11:42 PM
AlmostStock's Avatar
AlmostStock AlmostStock is offline
Re: Front End
Yes there should be 8 control arm bushings. Two upper and two lower for each side. The uppers are smaller than the lowers. Nova's do not have strut rods.
Since most (or all) of the front end parts are probably 35 years old, and you'll have it all apart anyway, you may want to consider changing all of the front end parts that can wear out. All 4 tie rod ends, 4 ball joints and the idler arm. I also like to get new springs at the same time, but be careful to get springs that will give you the final ride height that you want.
If you want the car to handle even better, get polygraphite control arm and stabilizer bar (sway bar to some) bushings from PST instead of the stock rubber type. It will feel the same as stock when going straight, but will not sway as much on turns.
BTW-What ever happened to "Battling rust"?
http://www.automotiveforums.com/vbul...d.php?t=525499
Mark's Garage est. 1983
Old 03-23-2006, 04:06 PM
Re: Front End
They did short me 2 bushings I got that taken care of. I got everything in the kit you mentioned plus sway bar bushings and end links. I considered full poly and I know they handle better but they squeal from what I've heard from talking to people. I did get the say bar bushings and endlinks though in poly cause thats the only thing they offered them in, everything else is rubber.
The rust is still there havn't had time to fix it w/ school and my dad and I always seem to having something going on around the house.
Thanks much for your time in replying to both threads, I appreciate it immensely.
Old 03-23-2006, 08:22 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: Front End
just grease em a little bit and they dont squeke(spelling?)
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
