Old 07-06-2002, 03:29 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Smile Got the strut brace onto the SiR
Ok - I had to unbolt the aircon brcket from the firewall and move it out a bit to fit the brace mount on the passengers (LH) side.
Not so bad but the drivers side was even more of a pain - resulting in having to undo the fuse box and then unbolt the wiring looms from the firewall as well. Fuse box bolted back up, and it still looks factory - so the spoon strut brace is go
Mind you, even though it was made for a EF8 SiR CRX, it only just cleared the vacume unit on the intake manifold - try half a millimeter clearance. I may have to raise the brace's mounts with a 1mm washer on each side to improve clearance to this - but so far there is no sign of the engine moving significantly and the two touching - I haven't put the boot in yet though
Anyway - there is a big difference - you can feel how tight the front end is now - corners are more precise and the car just feels right
Pics below:
SiR engine bay with brace installed:
Clearing the aircon piping (I've actually got another few mm out of the clearance since the pic was taken:
Still a tight fit - what clearance over the vacume control unit? Actually - this was why I couldn't use an Aussie brace - they were designed for the ZC and D15 twin-sidedraft carb setup and ran straight through this unit:
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 07-06-2002, 12:29 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
You could have probably used a Neuspeed one, unless you are strictly JDM.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-06-2002, 01:26 PM
bracer's Avatar
bracer bracer is offline
Or a Tenzo-R, fits great on EE9/EF9's
But hey, looks great man
So far for keeping it stock
WWW.CIVIC4G.COM
Old 07-06-2002, 05:27 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
damn you and ur SIR's over there, send me your car and ill send you mine, so you can feel LHD
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-07-2002, 02:30 AM
Setanta's Avatar
LOL - SiR singular. It's the only one in the country other than 1 or 2 EF8 CRXs. All private imports. It's the damn Kiwis that have all the SiRs - bastards
FourthGenHatch: Yeah - trying to stay as JDM as possible - and the spoon cost me 125 bucks Australian - that's about 60 bucks US - that's why I have it
Bracer: Well, it can be returned to stock by unbolting it so all is good Damn it makes a HUGE difference to the handling though
'99 PY DC2R
'85 BBS BMW E30
Old 07-07-2002, 02:39 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
It looks good!
Im amazed it made such a differnce to the handling though.
Makes me want one even more!!
:finger:
Old 07-07-2002, 02:54 AM
Setanta's Avatar
Originally posted by Moppie
It looks good!
:finger:
Huge difference moppie - frigging enormous. Going into a corner my car would roll quite heavily compared to now - 150km/h around a sweeping bend in the mountains and only the slightest amount of roll. I was going to put a bigger rear bar on to beat the roll - now I might just go to an 18 over the 14.5 instead of the 22 I was planning.
No-where near as tailey as it got (spunkymunky can attest to it's ability to spit the tail out - she was following in the VTiR 'teg last week) - full contact of both wheels to the ground even under tough conditions (IE me really putting the boot in).
I can't recommend it enough - I expected a little difference - what I got was an entirely different car as a result.
I need to shim it up higher though - the clearance worries me - but I hammered it gearing back a few times through the mountains on a cruise today - 8200 territory and it looks like the engine doesn't rock too much at all
'99 PY DC2R
'85 BBS BMW E30
Old 07-07-2002, 03:31 AM
Moppie's Avatar
Master Connector
Oh I know all about the oversteer!
Its lots of fun, but it can get a bit hairy under hard braking.
I suppose though that if you look at how light weight the standard chassis is, and how little hp the standard cars have to ours, along with all the under chassis mods, suspension, subframes etc it make sense that they must suffer from some bad chassis flex.
(it probobly explains why my bonnet is now sitting about 20mm higher at the catch than it used to).
But also remember that your not running standard weight springs, so any flex will be amplified, and so of course will any effect from a strut brace.
That said Im deffinitly going to be enqiuring about making one for my car.
(check your mail)
Old 07-07-2002, 08:03 AM
Strut Bars don't really improve handling, they just make steering a lot easier and smoother. They basically help hold the 2 sides of the car together so around turns it doesn't flex and creak it is held together.
Old 07-07-2002, 07:33 PM
Moppie's Avatar
Master Connector
It depends on the amount of flex occuring.
If its enough to alter the suspension geometry then a Strut bar will have a noticalbe and improving effect.
And in a little car with twice as much hp as it was ever designed for I would say that there would be enough flex to alter camber, caster and toe angles, all things that the SiR is very VERY sensitive to.
Old 07-08-2002, 05:10 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Once again, I would say that smoother, easier steering IS an improvement in handling.
Old 07-08-2002, 07:35 PM
Setanta's Avatar
Agreed ci5ic - I can't think of a better definition somehow More to the point, the car is now more precise in entering and leaving corners, not to mention more surefooted in maintaining tyre contact to the road.
If that isn't better handling then I don't know what is
Maybe there's another definition of "better handling" that I've missed
'99 PY DC2R
'85 BBS BMW E30
2008 Optima 4Cyl - Strut Tower Brace RidingOnRailz Optima | Magentis | Lotze 0 06-10-2010 04:48 PM
Replacing the struts & strut mounts Jmalbright Alero 8 03-15-2010 10:21 AM
"Generic" Strut Tower cross Bars? RidingOnRailz Engineering/ Technical 3 06-15-2009 11:40 AM
Got the strut brace in... Setanta Asia/Pacific 42 12-20-2002 04:56 AM
got my strut brace... AccordCE8 Europe 8 12-29-2001 12:24 PM
