Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 03-17-2006, 02:09 PM
elow5x elow5x is offline
Acceleration problem after dealer repair
After I had the intake manifold repaired on my 97 CV, I now have a very distint hesitation at around 35 thru 45 miles mph as the transmission is shifting to next higher gears. If I go very easy on the acceleration through this range the hesitation is very subtle. It occurrs about 3 out of 5 times but was difinitely not there before the repair. Any insight anyone??
elow5x
Old 03-18-2006, 09:36 AM
Shick1988 Shick1988 is offline
Re: Acceleration problem after dealer repair
I have the same problem at WOT hitting second gear, she lays down for a few seconds and then picks back up. I posted something similar to this before and was told its the nature of the beast. I cant cross reference my car before the new intake because I didn't own the car when the original cracked. Maybe there is some connection.
Old 03-18-2006, 10:11 AM
ModMech's Avatar
ModMech ModMech is offline
elow,
I would think this may be a vacuum leak problem. The transmission is computer controlled, so a vacuum leak does not have any DIRECT impact on shifting, but engine RPM and driveablilty are VERY MUCH affected by vacuum leaks.
Old 03-18-2006, 04:15 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Check the throttle position sensor to be sure it is plugged in properly.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-15-2006, 01:57 PM
Thought I had my problem solved when I got a P0303 code, checked then replaced cyclinder 3 spark plug. Ran fine for about 2 or 3 weeks then P0303 code (with blanking Mal light) came back. Checked spark plug wires and coil packs. Primary of all coils read lower than the spec (about 1.5 ohm vs 8-9ohms per spec however I haven't gotten any error codes on any other cylinders
Old 06-03-2007, 02:16 PM
divienctp divienctp is offline
i get the same problem when i pull off but once it hit 15mph it all good what going on ??????
