Old 03-13-2006, 04:51 AM
klutz_100's Avatar
Topless Trio: 365GTS/4 Daytona
This thread is part of a joint venture with Gionc and MPWR (no, we are not trading in cannabis!) so please check out their “topless” threads too!
My first impression of this Fujimi Enthusiast kit when I opened the box was WOW!!!
It’s a very detailed kit with about 6 million pieces. My favorite tree in the box is the one with about 20 1/24 scale tools including screw drivers, wheel jack and oil filter wrench – those are going to be hell to paint!
You can click on the thumbnail to see a high res image of the box contents:
Closer inspection has shown that there are a few fit issues that will need sorting and a few parts that will need to be re-shaped. None the less, this is still one heck of a kit and the guy who made the master put in a lot of effort IMHO.
While doing some web research for this car (big thanks to Ales for some great images ) I was surprised that I couldn’t find a Enthusiast build thread anywhere on the web so I’m having to go with this (my 6th model) pretty much solo
I have no fixed idea yet about the colour other than it won’t be red. I will probably go for something in the blues- maybe dark blue?
In our common “Topless Trio” thread we agreed to start with the engines.
This is about the only place where I will have any kind of a head start on Gionc and MPWR as I have 12 cylinders to their 8
The 365 engine is made up of over 36 parts and they seem to be very well modeled after the original.
For the rocker cover scripts I decided to try the BMF “paint ‘n scrape” technique.
First I applied a small strip of BMF over the lettering and put it into place with a dulled toothpick.
Then this was sprayed with a mix of Tamiya flat black and dark grey with a lot of thinner to give it a rough finish.
The paint was then gently scraped off of the BMF with a toothpick.
Everything was painted first with various Alclad2 metalizers.
The carburetors were painted with A2 Pale Gold – this is not accurate but I wanted some colour variation in the engine block.
About the only thing in the engine that I could find that I didn’t like were the distributors – specifically the caps which are not shaped at all like the originals.
You can see here the difference between the two “F”s (Ferrari and Fujimi):
If I left it like that, the wiring would look like a fountain from Versailles so I tried to create a more correct distributor cap.
I was inspired a lot in this by our friend, “Spruemaster” quadzero who has proved that you can make anything out of sprue!
I used 2,4mm sprue for the base and 3 pieces of 0,8mm glued together for the upper connectors.
The upper connectors were then glued, trimmed and sanded to shape
and then painted with a mix of X-18 and XF Dark Grey
Because I have a couple of 365 GTB/4s and 275s in my stash, si I made an RTV mold and cast some resin copies for future use.
Thanks hirofkd for the idea
Another thing I wanted to try out for the first time was adding fuel rails(?)
This was actually pretty easy to do.
For the pipes I used 0,5mm steel rod and the hose was made out of wire insulation.
To fix the rails to the carb housing I used hex rod which I drilled to allow the rod to pass through.
Fun from doing this - 100%; Results not too bad -90%; Visibility of scratcbuilt part after assembly – 15%!!
Time to wire the plus and distributors. I’ve only done this twice before and both times it looked a bit mediocre – this time I’ve 14 of the buggers to do and have to keep it all pretty much symmetrical !!
I cut off Fujimi’s distributor caps and fixed on mine and then working in pairs I started adding each HT lead making sure I had 2 identical cables before fixing in place with CA glue (first into cylinder head and then into distributor)
I test fitted after each cable to make sure it all fits
and so on and os on. I think it worked just fine though.
Next to do alternators, pulleys, starters etc.
Thanks for looking in and please check out MPWR’s 360 and Gionc’s 348ts
Old 03-13-2006, 05:01 AM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
Re: Topless Trio: 365GTS/4 Daytona
You guys stole my post name!!! Bastards!!! oh well, see you MPWR at NNL anyhow, bitches........ thiefs.... Topless....... i hate you i love you...(Dead Milkmen song)
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
Old 03-13-2006, 07:58 AM
AmazonSprite AmazonSprite is offline
Wow! Looks like an amazing kit, and with the way you're building it, will be a fantastic model when finished. Makes me want to build my Fujimi Enthusiast Porsche 356 Speedster as my next project!
Paul
'67 Amazon 122S B20 o/d Estate & '61 A-H Sprite Mk2 948cc
Old 03-13-2006, 08:04 AM
sjelic's Avatar
sjelic sjelic is offline
You got to love that kit, I mean I love each and every model from enthusiast series (in 24 of course )
Well done for improving perfection
Sasa Jelic
SCALEMAKERS
Old 03-13-2006, 08:34 AM
joelwideqvist joelwideqvist is offline
Wow, great work. Inspiring.
Thanks
Joel
Old 03-13-2006, 08:43 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Congrats Steve: great job! I love distributors and that beauty of fuel line
and super job with BMF!!!
gio
Old 03-13-2006, 08:46 AM
auw12's Avatar
auw12 auw12 is offline
oh just incredible,awesome details!i just ordered my daytona gtb from hlj,really nice the FUJIMI enthusiast kits!
Old 03-13-2006, 11:09 AM
sportracer02's Avatar
Great job so far, this will turn out great !!!!!!!!!!!!!
Micha
Old 03-13-2006, 11:21 AM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Gorgeous. Engine detail is magnificent so far.
Old 03-13-2006, 01:33 PM
Rosco P. Coltrane's Avatar
Rosco P. Coltrane Rosco P. Coltrane is offline
That looks sweet as hell. The engine has great detail and the wiring looks absolutely amazing.
Rosco P. Coltrane
Old 03-13-2006, 03:21 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Beautifully done as ever, Stevenski. I wish I could have built like that on my sixth model.
This will be another kit I'll need to aquire sooner or later.
Clever that idea with the BMF!
PHOTOBUCKET SUCKS
Old 03-13-2006, 03:24 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Superb scratch work on those distributors, I hade to do a double take as I was unsure if those were kit parts or rebuilt.
-Mike
Old 03-13-2006, 03:41 PM
agamo's Avatar
agamo agamo is offline
Send a message via ICQ to agamo Send a message via MSN to agamo Send a message via Skype™ to agamo
Great Start!!
Go on, and let us see more!!!!
Cheers!! great job!!
Happy modeling!
Ramon Garcia
Puebla, Mexico
Old 03-13-2006, 04:57 PM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
nice idea with the BMF!
Old 03-13-2006, 07:39 PM
eph2 eph2 is offline
Send a message via MSN to eph2
Wonderfull Work!!
