Old 03-13-2006, 02:18 PM   #1
MPWR
Image Hosting Exceeded
MPWR's Avatar
Topless Trio: 360 Spyder
This is my part of the three way that Klutz_100, Gionc and I are having. (And you thought I was going to say "joint venture"). Be sure to check out their threads, also. We'll update the joint thread (there I said it) too, as we work on other subassemblies.
No, I can't say I really needed to start another full engine Ferrari- but they ganged up on me and made me do it! The Mythos and F40 are both still underway, and sooner or later I'll update them, I promise.
But, as
Klutz_100 and Gionc were sooo persuasive- may as well make the best of it, right?
Tamiya's 360 Spyder is not so uncommon a build around here as either the Mythos or the F40. I expect it's perhaps second only to the Enzo as the most seen Ferrari on AF. This is in part due to the fact that it's a lovely kit, one of Tamiya's very best efforts. This is fortunate for me, as it doesn't require much to make it a rather spectacular model. So I will try to keep additional superdetailing on this one to a relative minimum, to 'relax' and 'enjoy' it, and try to finish it this year (or even this summer?). We'll see how well I do. On the other hand, it will of course be displayed in the complany of the F50, F40, and Mythos so I really can't slack off that much, can I?
And no, it's not going to be red, or yellow. I'm going to delve yet again into the more obscure areas of Ferrari's color pallette....
But enough talking, on to building!
The 360's V8 is very well molded, as you would expect from Tamiya. But that doesn't mean they weren't above a shortcut or two. After studying the engine, I decided that the oil line running into the sump under the engine was going to bother me if I didn't fix it.
Notice the otherwise rectangular hole for the oil pan has a cut in? The oil line on the actual engine is separate from the pan. So, time for a little surgery.
Original kit part on the left, new and improved on the right. It fits the shape of the underside of the engine block now.
Next, the oil line will need to be replaced.
DetailMaster braided line. I hate working with this stuff , but if you can get it to behave, it can look great. The fittings on the ends were turned on the lathe.
Installed. Better, I think. But, it's really only going to be visible from below. Oh well.
Next, the intakes.
Ferrari went to a bit of effort to make the intake manifold spider and plenums visible on the actual 360, so the kit parts worth a bit of effort to make them presentable. The Ferrari emblems on the red cracle finish plenums are particularly eyecatching.
The kit parts are of course well molded, but I was a bit disappointed to find that the logos were not engraved on the plenums, but included as self adhesive PE parts. While I like SE PE for mirrors and body logos, it's not a particularly accurate way of representing them here. The logos are cast as part of the plenums, which are then painted red. The logos are them revealed by grinding the red finish off of them, showing the alloy color undernieth.
To replicate that look, I applied the logos onto the bare plastic, then masked off the inlets to the air filters.
The texture of the crackle finish was then applied by spraying the part with laquer primer- I used CobraColors Moon Mud. Moon mud is terrific stuff, but it really needs to be thinned. Sprayed straight, it bumps up nicely.
Here are the results. The logos were revealed by gently scraping the primer off of them with a sharp toothpick soaked in 99% isopropyl alcohol. Notice the nice contrast in textures versus the bare unmasked plastic?
Everything gets oversprayed with thinned flat red (I used MM Acryl insignia red), and the logos again get scraped clean.
Time to detail it. Tamiya includes the Cavalino logo between the plenums with the chromed parts.
In reality, this part has a very cast, grainy appearence to it- so, off comes the chrome. Tamiya flat aluminum looks about right.
Detailed.
The hose clamps are of course BMF (what else?!).
Ready for the engine.
Still needs work, but it's a start. Next I'll need to add an oil filter, and wire up the ignition coils.
Thanks for watching!
PHOTOBUCKET SUCKS
MPWR is offline   Reply With Quote
Old 03-13-2006, 02:33 PM   #2
klutz_100
klutz_100's Avatar
Re: Topless Trio: 360 Spyder
Awsome as ever
Amazing lathe work on those oil line end thingys - what diam hose did you use?
I like the sound of this moon-mud gunk!!!! Shame I'll never get any
And I did think you would say "joint venture"
Old 03-13-2006, 02:44 PM   #3
gionc
Authorized Vendor
gionc's Avatar
So the intake's secret is moon-mud.. fun CobraColors!!!! Lioooooooooooon we neeeeeeeeeeeeeeeeeeeeed it! Or I can't close my 360CS
Awesome as expected and that turned oil bit is yes tooo close, I agree with Steve.
And as an answer about how persuasive we was a wooden box filled of chiantileave today Italy
gio
Old 03-13-2006, 03:27 PM   #4
sportracer02
sportracer02's Avatar
MPWR,
Nice to read your WIP thread. I learn from you ...
Micha
Old 03-13-2006, 03:47 PM   #5
toyota00
That is awsome, I want to see some more progress... Goodjob
toyota00 is offline   Reply With Quote
Old 03-13-2006, 04:16 PM   #6
NissanSkylineGTR98
NissanSkylineGTR98's Avatar
Looking forward to seeing more progress
Steve
NissanSkylineGTR98 is offline   Reply With Quote
Old 03-13-2006, 04:54 PM   #7
D_LaMz
D_LaMz's Avatar
looking good!
D_LaMz is offline   Reply With Quote
Old 03-13-2006, 07:40 PM   #8
eph2
Send a message via MSN to eph2
Nice start. This engine is gonna be another cool work!
eph2 is offline   Reply With Quote
Old 03-13-2006, 08:08 PM   #9
rx7king
rx7king's Avatar
stunning work. This is very helpful for all the hundreds of people on this forum building similar ferraris. interesting take on the little oil line..i like it!
rx7king is offline   Reply With Quote
Old 03-13-2006, 09:48 PM   #10
Crazy_Modeler
Banned
Crazy_Modeler's Avatar
Send a message via MSN to Crazy_Modeler
nice job ,man.
you are really something.
I will definetely contact you.
Crazy_Modeler is offline   Reply With Quote
Old 03-13-2006, 10:03 PM   #11
Merkava
Merkava's Avatar
Send a message via AIM to Merkava
Hey, MPWR, I'm lovin' it already! This Tri-build is the absolute $h!t... Gonna be watching especially close!
The name is Sam.. and I'm ready to rock
TRIUMPH!
Merkava is offline   Reply With Quote
Old 03-14-2006, 12:17 AM   #12
0tobe60in10minutes
0tobe60in10minutes's Avatar
Send a message via AIM to 0tobe60in10minutes
some hard core shat going on here, haha pimp
RIP 88 Bronco II
0tobe60in10minutes is offline   Reply With Quote
Old 03-14-2006, 01:15 AM   #13
sjelic
sjelic's Avatar
What to say but perfect, moon mud is definitly the stuff to get
Sasa Jelic
SCALEMAKERS
sjelic is offline   Reply With Quote
Old 03-15-2006, 08:33 PM   #14
MidMazar
MidMazar's Avatar
I love seeing threads like this, clear and easy to understand with rediculous amount of detailing.
In Progress
Old 03-16-2006, 01:10 AM   #15
auw12
auw12's Avatar
can i be a student of yours Mr.MPWR
auw12 is offline   Reply With Quote
