Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 03-09-2006, 11:12 PM
rachaelstarr rachaelstarr is offline
cracked exhaust manifold/bad o2 sensor
Okay so after quite a bit of troubleshooting, it turns out that my exhaust manifold is cracked (whether or not this caused the o2 sensor to go bad, i don't know).
So my first question is: can/should it be welded? If not, does anyone know where i can get a california acceptable manifold? i haven't been able to find an aftermarket one, only from honda...
any help is appreciated
rachael
Old 03-10-2006, 10:05 AM
hxgaser hxgaser is offline
Re: cracked exhaust manifold/bad o2 sensor
Take the car to a good muffler shop. Of course it depends on the location of the crack, but sometime they can weld the cast iron manifold without a problem. The other option is to go to s junkyard and pick one up. Like you say aftermarket manufacturers make headers, not exhaust manifolds. Anyways, good luck.
Old 03-10-2006, 02:17 PM
GreenGeckoUSA's Avatar
GreenGeckoUSA GreenGeckoUSA is offline
I had the exact same problem as you. Don't know about welding it but I had mine replaced (the Cat). around $800 - my o2 sensors were fine. I actually drove with it like that for a few months and didn't have any problems - I only had it fixed because it was time for my emissions test. Good luck getting yours fixed.
Old 03-10-2006, 06:23 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
http://www.automotiveforums.com/vbul...d.php?t=497033
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-18-2006, 06:55 AM
azwethinkweiz azwethinkweiz is offline
i had this exact problem as well..
I actually drove my car for about a year with the manifold cracked.. hah!
stock manifolds are expensive... so I did this:
bought a header with an o2 bung..
and installed a straight "racing" cat for the secondary o2.
works like a charm. =)
As for welding it... not such a good idea.. My best friend is a welder.. he welded my manifold.. and it only lasted for about 2 weeks...
Oh.. by the way.. the crack gets worse if you do nothing about it..
I was probably down to about 85 horsepower.. haha.. oh ya.. it was NICE..
Annd.. yes.. the manifold being cracked will effect your o2.. I replaced it twice in that year..
damn Im lazy..
Old 08-31-2008, 11:44 AM
turbo1974 turbo1974 is offline
You can have the manifold welded with a powder tourch welder with 100 percent success I have been welding cast iron exhaust manifolds for the last 15 years every thing from cars to boat and tractor manifolds with no problems.
