Old 03-08-2006, 01:57 AM
88Porsche944 88Porsche944 is offline
Angry The paint peeled.
O.K. I have read the F.A.Q's and done a search, but I still don't understand why the paint peeled on my model. I'm working on a Ferrari Enzo. It is the first time I have used nail polish as paint. I primed the car about a week ago and have let it sit (covered) but put a toothpick under the box to let it breath. The type of nail polish I have used is called Santee nail laquer. Can anyone give an idea why it has peeled?
Thanks,
Trevor
Old 03-08-2006, 02:04 AM
michael1978's Avatar
michael1978 michael1978 is offline
Re: The paint peeled.
I have sometimes the problem with peel whan the paint is not liquide enough for the airbrush . Or if i apply to may coats at one time .
IN Progress Fujimi EVO 5,6,7,8 with HOK Kameleon Colors
http://www.automotiveforums.com/vbul...9&page=1&pp=15
Old 03-08-2006, 02:14 AM
chato de shamrock chato de shamrock is offline
Can you use nail polish colors on model cars? I've never heard of it before. Wouldn't the paint come off with time?
HEY!!! HEY!!!
Old 03-08-2006, 07:31 PM
49 views and 2 replies???? Anyone else out there??
Old 03-08-2006, 09:43 PM
hirofkd's Avatar
hirofkd hirofkd is offline
That is probably because this question is hard to answer. Suggesting other brand is easy, but it doesn't solve your problem. (that's why it's difficult)
I've seen some people using nail colors for car modeling, so it's possible, but you have to find the right brand, and that takes some trial and error.
I guess the paint film of this particular brand is so inflexible that it doesn't like the plastic body part.
If you can't make a switch to more conventional hobby or auto paint, my advice is to mix the nail polish with a compatible clear paint. That might be able to make the mixed paint more flexible. (But that will make the paint translucent, so it requires more coats. Be careful not to lose any surface details.)
Whether finding the right kind of nail polish or compatible clear, you'll need to do some experiment.
Hiroaki Fukuda
Old 03-08-2006, 11:53 PM
Hiroaki,
Thank you for the reply, I was hoping for some imput like this.
Again.Thank you.
Trevor
Old 03-09-2006, 12:27 AM
Might i suggest Cover Girl. Tyra Banks is one of their models
HEY!!! HEY!!!
Old 03-09-2006, 03:56 AM
RallyRaider's Avatar
Zomby Woof
So, did the paint/primer peel or the nail polish?
Old 03-09-2006, 09:58 AM
Both unfortunately. The primer was fine until the nail polish was airbrushed. I'm going to strip what is left of it today and reprime. What do you think would be a sufficient wait time before paint?
Trevor
Old 03-09-2006, 11:49 AM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
There's no easy answer for this.
For a paint job to work, everything has to work together.
The primer could have been too wet or too dry, or simply not compatable with the FNP. You may have thinned the FNP with a thinner that dryed too quickly or that reacted with the primer. You did'nt even get to the clear coat which is where a lot of problems come.
On one of my FNP experiments the FNP simply never hardened, even after a month it was still tacky to the touch.
SCCA 7, The lost Z
Old 03-09-2006, 01:18 PM
proudfordowner's Avatar
proudfordowner proudfordowner is offline
hmm.. ya i tried to paint my lambo once and after a day of drying... it started to wrinkle.. BAD
and it was soo rough that it looked part of the car
i mean wrinkles half an inch high it sucked
i don't know why i had to respray it with different paint for it to come smooth
i've moved on from that and i got an airbrushing kit, it's so smooth and clean..
i would recomend airbrushing to ANYONE
im sorry i couldn't help
good luck
proud owner of a 2003 Ford Mustang GT
my h3 hummer rulez!!
VISIT MY CAR ROOM
http://www.automotiveforums.com/vbul...d.php?t=521391
Old 03-09-2006, 03:32 PM
Zomby Woof
Trevor
Well that has thrown me. I can imagine contamination or poor surface preperation preventing the primer form sticking and incompatibility or lack of bite making the nail polish peel. But application of the top coat causing the base coat to peel is just plain weird!
Old 03-10-2006, 08:28 AM
BWheel BWheel is offline
Did you wash the model completely and correctly prior to priming?
What primer did you use? (many automotive primers don't stick to plastic effectively)
How long did you leave between:
Washing and priming?
Priming and Final Coat?
As RallyRaider has said - it sounds like incompatible primer or bad surface prep. Give it a go with standard model paints, and check what happens. If that works OK, it is most likely the paint reacting...
Completed:
Tamiya Subaru WRC Monte-Carlo
Revell Eddie Hill Top-Fuel Dragster
Revell T900 'Australia'
Tamiya Enzo Ferrari
Tamiya Honda NSR
Current Project:
Revell Fire Truck
Old 03-10-2006, 09:48 PM
Dupicolor primer, I've used it before, never had an issue.
I washed it in water with a tiny bit of soap, washed throughly, let it sit for about four hours, primed it, then let it sit about a week. Then the color coat, 2 mist coats, waited about two hours, then 2-3 wet coats.
Old 03-11-2006, 08:23 AM
Vric's Avatar
Vric Vric is offline
How to Paint Models With Nail Polish
As Phil said, body preperation is probably your problem
