Old 03-07-2006, 06:12 PM
patoffspyder patoffspyder is offline
Painting with spray guns?
Hi guys!
I started using Createx Automotive paint with my airbrush but I got problems with some colors, because my airbrush is too small, I got a .3mm nozzle...
On the box, they said a 1mm nozzle should be use. So I was wondering if any of you guys paint with spray guns, something like this :
http://cgi.ebay.com/ebaymotors/HVLP-...QQcmdZViewItem
Does it works good? Does it have any advantage over a regular airbrush?
Thanks!
Old 03-07-2006, 07:14 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Painting with spray guns?
Haven't ever tried it, but I always figured it would be like trying to brushpaint with a wall roller.
I would think a larger size nozzle for your airbrush, or using more thinner, wuld be a better option. What kind of airbrush do you have?
PHOTOBUCKET SUCKS
Old 03-07-2006, 07:39 PM
I got a Badger 360. Don't know if there is bigger nozzle for this type of airbrush...
Old 03-07-2006, 07:46 PM
freakray freakray is offline
AF Modelrater
You should check their website, I am sure it will tell you if other parts are available: http://www.badger-airbrush.com/
AF User Guidelines
Old 03-07-2006, 07:55 PM
Thanks, I took a look, but there is no extra nozzle size available :-(
Old 03-07-2006, 08:47 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Using spray guns is extreme overkill for anything smaller than 1/12. You'll usually lay on way too much paint.
-Mike
Old 03-08-2006, 01:29 AM
hawkone hawkone is offline
Send a message via AIM to hawkone
hi i use the badger 360 and i only use tamiya paint with there thinners no problems the needle is a one size universal needle fine to large double action the more you pull back the bigger the spray pattern you can set the size of spray and use the 360 like a single action. with the createx they need to be thinned more there is a nice tutorial on another site bmc brians model cars i dont know how to add the link i'm sure someone knows and can hope this helps.
Old 03-08-2006, 08:39 AM
Vric's Avatar
Vric Vric is offline
Isn't the 360 have a .5 needle anyway ?
Thin the paint.
Old 03-08-2006, 09:32 AM
toyota00 toyota00 is offline
Thin the paint.
He said he has a .3 needle, and it tells him to use a 1mm needle. So, I don't think he has the .5 needle...
Old 03-08-2006, 04:43 PM
Maybe I have a .5mm needle, not sure about it. But I guess you're right, I don't even use full opening when I paint, maybe this is the problem...
hawkone, can you give me the link to this tutorial, I didn't find it. Just copy the link and paste it here, even if the hyperlink is not working, I can copy and paste the address :-)
I gonna try different combination and look at the result, thanks a lot to all of you!
Old 03-09-2006, 02:06 AM
if you type in www.briansmodelcars.com it should take you to the web site search in his tutorial section hope it works
