Old 03-07-2006, 04:06 PM
Pac-Man_G Pac-Man_G is offline
Send a message via AIM to Pac-Man_G
Need to know if it will work?
Hey guys, i need to know if the LT1 camshaft will lift into my 305 TBI V8 without changing the rollers, valves whatever... also would it take a lot of work and money to convert the motor to carbrator? what will need to be done? also lol i have an automatic with super long gears, does anyone know what size come stock on a 92 RS? and what will be some good gears for street riding/racing THANKS! If you could help
Old 03-07-2006, 05:45 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: Need to know if it will work?
If you dont do alot of highway driving go with 4.11 gears if you do then go ahead and go with 3.73, but since its an automatic.. thats what alot of people here go with, so i'd recommend 3.73 over the 4.11 gears.
Old 03-07-2006, 05:58 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
for the cam, all you need is diffrent valve springs for valve train wise, and remeber you have to get your prom redone also. and i would highly recomend to change the timing chain while it is off. i plan on doing this swap when ever i see a good deal on a lt1 cam.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 03-07-2006, 05:59 PM
97cavalier's Avatar
And why would you want to switch to a carb? it is basicly a carb now, it is just fuel injected carb.
Old 03-07-2006, 07:23 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
go with 4.10s (or 4.11s)
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 03-07-2006, 10:47 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
go 4.11 if all you want is off the line punch and very little at speed.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 03-08-2006, 08:24 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
lifters
Old 03-08-2006, 08:32 AM
Link85x Link85x is offline
Get timing chain, matched valve springs, and all the gaskets you gonna need to replace. Like 97cavalier said, get your prom redone aswell. I have my cam and timing chain already, but i'm not installing until sometime this summer, while i'm in school. Free dyno tuning and runs, also gonna install a small supercharger while i'm at it. Should be fun.
87 IROC - R.I.P, and she will never be forgotten
90 RS - The beginning of a new era... I hope.
Old 03-08-2006, 09:00 AM
wrightz28's Avatar
Cam swap with no new lifters = why bother?
Old 03-08-2006, 11:42 AM
97cavalier's Avatar
what? i will need new lifter also when i do my lt1 cam swap? they said all i need is new springs.
Old 03-08-2006, 11:56 AM
Well, if your on a really tight budget. But the correct way would to replace evrything that would be involved with cam swap. Not everything, but you know, everything!!!!!!!
Old 03-08-2006, 03:36 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
UH you need to change the lifters at the same time, you can use new lifters on a old cam but never used lifter on a old cam or if they arnt original, also dont get them mixed up. REPLACE THE LIFTERS!
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 03-08-2006, 08:06 PM
97cavalier's Avatar
ok, so can i order stock lifters for this cam? New but to stock specs? Or will i have to get some with more lift?
Old 03-09-2006, 08:14 AM
wrightz28's Avatar
When you buy a cam, it should come with matched lifters for the application. Not only will you have the proper lift rate (ie lifters), bu tI'm sure you'd be really pissed when you go through the work of putting a cam in and find out it's only performing at 60% of it's capapbility due to high mileage partially collapsed and incorrect lifters.
Push rods would be a good cheap idea as well. When you take them out, roll them on a flat true surface, I'll be willing to bet they are bent.
Old 03-09-2006, 12:03 PM
97cavalier's Avatar
ok, well i was going to get a good used lt1 cam, so i think i will buy it and slowly buy every thing new besides the cam.
