Old 03-06-2006, 04:53 AM
pollapellos pollapellos is offline
paint remover-glue remover
hello.i need a paint remover liquid product and a glue remover.can someone tell me exactly the name of this products so i can find them on ebay?and also a manufacturer of this products,is it tamiya?... thanks
Old 03-06-2006, 05:07 AM
wouter1981 wouter1981 is offline
Re: paint remover-glue remover
for paint remover i use isopropyl alcohol. For glue it all depends on the type of glue. Just check the FAQ and the search function. These items are discussed over and over again..
Old 03-06-2006, 08:51 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
The more information you give in your question, the better the answers will be. What kind of paint? Is this a fully assembled kit you want to rebuild? Posting a couple of pics of what you're doing is always helpful.
For stripping all paint except enamels, use 99% isopropyl alcohol, from your local drugstore/grocery/chemist. Soak the parts in a covered container, scrub with old toothbrush as necissary.
TO unglue parts, try sticking them in the freezer for a couple of hours. Be warned, it can make the plastic brittle, so you're almost as likely to break the parts instead of removing them. there is no really safe way of ungluing parts.
PHOTOBUCKET SUCKS
Old 03-06-2006, 01:43 PM
356speedster 356speedster is offline
Micromark got a CA Debonder I've Never tried it, but if it does what it says, then it could be worth a try.
---356 speedster---
Trying again! - Links to the old wip's (still searching for the old pics): 911 Turbo '88 - Fiat barchetta- Lotus Elan 26R - 928 S4 - 944 turbo - 924 turbo
Old 03-07-2006, 12:37 PM
600sel's Avatar
600sel 600sel is offline
Castrol Super Clean - Cleaner Degreaser. Need one myself, searching.
See also this linkt: http://www.bonediggers.com/1-3/strip/strip.html
Old 03-07-2006, 05:01 PM
toyota00 toyota00 is offline
The alcohol and brake fluid is what I have heard works.
Pollapellos- READ READ READ the FAQ- ALL of them... it will help you alot, I am not trying to be rude or anything, but you have asked like 10 questions in the past week or so that are all in the FAQ. Don't take this as being rude, I am just trying to help you so you do not have to wait for responses, and you get alot clearer answer.
Old 03-07-2006, 06:26 PM
lonelywolf8588's Avatar
lonelywolf8588 lonelywolf8588 is offline
Paint strippers
I need a paint stripper for a plastic model that I painted with a lacquer paint. I tried citristrip and it ate the plastic. Any other strippers that are good.
Old 03-07-2006, 06:37 PM
patoffspyder patoffspyder is offline
Re: Paint strippers
If you live in North America, you can get Castrol Super Clean, it works great, it will remove the paint without damaging the plastic. It costs 5$ Can for a bottle, and you can clean multiple car with only one bottle. This stuff save 2 kits for me :-)
Old 03-07-2006, 06:40 PM
MPWR's Avatar
Re: Paint strippers
CSC is terrific for acrylics and enamels, but it frequently doesn't work so well for laquers. For laquers, get a bottle of 99% isopropyl alcohol at your local drug store/grocery/chemist. Use in a covered conteiner, soak overnight, and scrub off any stubborn bits with an old toothbrush.
PHOTOBUCKET SUCKS
Old 03-08-2006, 02:57 AM
DarrenGR's Avatar
DarrenGR DarrenGR is offline
Hi, this is probably a dumb newbie question, but is bleach that only works for the chrome covering on plastic and it won't work for paint? Was about to dip some wheels that I'm not happy with and no point if the bleach isn't going to have any effect on them!!
Cheers
Darren
