Old 03-05-2006, 08:09 AM
ifishalways ifishalways is offline
Exclamation signal/indicator fault
hi
got a slight problem with my signal/indicators.
they both work fine when the engine is switched off, but as soon as i start the car the left hand indicator flashs very rapidly, and the right hand one works normally. when i turn the ignition switch to the on position they both work fine, its only when i actually start the car they go wrong. the ignition barrel is only about 12 months old, have checked bulbs and they all fine. obviously it sounds like there is a short somewhere, but where do i start looking. could it be the ignition barrel, or the signal arm itself.
any thoughts welcome.
Old 03-05-2006, 01:10 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: signal/indicator fault
It could be a sign that a bulb is darn close to being done. Sometimes when they're on their way out they give a lot of resistance which makes the flasher go fast. Its also possible that one of the bulbs has some corrosion around the base causing resistance to spike.
Dragging people kicking and screaming into the enlightenment.
