Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-01-2002, 09:14 PM
dbiggss dbiggss is offline
Lightbulb Max PSI?
How Much PSI could be run safely out of a built up H22(forged bottom end, low compression pistons, etc.) How much are all of you turbo luders running? :rocket:
Old 07-02-2002, 10:08 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
depends on the compression and tuning. some h22 runs 15psi safely and some run 18psi. if you are good with engine management system, you will be able to boost more. now i don't believe in lowering compression. it just makes more lag and gains are not that great.
Recommended psi verses Max psi. mchapman Tires and Wheels 27 02-26-2019 07:46 AM
Psi CAL2800 3000GT/Stealth 5 05-17-2010 10:31 AM
Tire MAX PSI -Jayson- Non Specific 16 02-16-2006 02:44 PM
Max. PSI eclipser2001 Integra 23 04-16-2005 08:09 AM
max psi on a 20g and 16g??? maverick27 Off-Topic 8 04-12-2004 02:29 AM
