Old 07-01-2002, 05:34 PM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
d16z6 and d16a6 compatibility...
Are the flywheels and clutches interchangeable between the 2? I met a guy with a lightened flywheel and clutch off of his z6 and I am thinking of buying them. Thanks for any help.
Old 07-02-2002, 12:40 AM
Bump...Anyone, someone has to know.
Old 07-02-2002, 10:14 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
as long as you keep the flywheel and clutch the same...it should work with the a6 tranny. most of the clutches out there 90-00. nc_rex once broke it down (with pics and all) and showed the difference (if there was any) in clutches from 90-00.
the key is to keep the same flywheel as clutch
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 07-02-2002, 11:32 AM
Thanks Ami, Ill post here if I actually get the clutch and flywheel and update.
Old 07-02-2002, 03:47 PM
amy@af's Avatar
no problem! that's what i'm here for .
how much you gonna try and get them for? if you don't plan on getting the flywheel lightened...you should consider having it resurfaced.
a) it makes the flywheel like new
b) resurface=shave some off. it ends up being slightly lighter :ylsuper
just something to think about before you drop it in...
ami
Old 07-02-2002, 04:01 PM
The flywheel is already an 11 lbs flywheel, I dont think it needs to be any lighter. As well as a stage 3 centerforce clutch.
[IMG]http://groups.msn.com/_Secure/0PABpZQ8Vv30KLSFOtY9CWnc4ukY8Gwpur8MzivXI9Il*fEfdN YFR0GNzxRZiGOihD93P6nuYc5tn!pauZienNdt1aAIsqCWy/flywheel-copy.gif[/IMG]
D15b8 and d16a6 heads Honda_maniac '88 - '91 Civic | CRX | Wagon | Shuttlee 0 05-22-2005 11:07 AM
ARP Head bolts and D16A6 dssmax '88 - '91 Civic | CRX | Wagon | Shuttlee 8 08-04-2004 08:18 PM
Are the D15b2 and D16a6 Headgaskets the same? CR50HC '88 - '91 Civic | CRX | Wagon | Shuttlee 4 06-27-2004 03:10 PM
d16z6 and bost how much krondor22 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 09-01-2002 12:31 PM
