Old 07-01-2002, 12:52 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
Question brake troubles
please help....
my wifes accord wagon freaked out on her a few days ago.
she heard a strange noise and the brake pedal slowly went down to the floor as she came to a stop...
i took it out about 10 minutes after she got home and nothing happened.
went went somewhere this weekend and it happened on and off, mostly after we had been driving for a while...
it will be ok then we come to a stop and the pedal will start going to the floor slowly then the starts rolling cause it's an automatic. if i pump the brakes once or twice it stops sometimes..
is it air trapped? master cylinder? what?
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 07-01-2002, 01:35 PM
vik vik is offline
Send a message via AIM to vik
i have the same problem with my accord. the guy at midas told me that it is a good chance that it can be the cylinder. but im not sure.
1998 Mustang GT (Black)
MAC CAI
Flowmasters
2 12's JL Audio W3's
Pioneer DEH-P4500 (Deck)
MB Quart Speakers (4)
Crunch Amp (Speakers)
HiFonics Amp (Subs)
Solid Audio Tweeters
XM Radio
Old 07-01-2002, 02:07 PM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
yup it's the master cylinder, or it could be one of your screw bleeders that don't keep the air out, but i'm 95% sure that it's the cylinder
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 07-01-2002, 03:39 PM
HONDA_99 HONDA_99 is offline
its a master cylinder, to be more accurate its a bad seals. i had that problem with my 89 Accord many years ago.
i have a suggestion, don't to be cheap and get OEM master cylnder, if you get aftermarket you will have to replace it pretty soon.
for Honda OEM parts check this place out -> http://www.hondaautomotiveparts.com/
Old 11-21-2002, 10:36 PM
Craigmax Craigmax is offline
Send a message via AIM to Craigmax
Question master cylinder
Any threads on changing the master cylinder? All help appreciated!
Old 11-22-2002, 12:12 AM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
If the pedel is being brought down to the floor it may be your booster. that is what wa happening to my civic
My Name is Roberto AKA. Berto
Old 12-05-2002, 12:06 AM
vik vik is offline
i finally got my new master cylinder put in. it cost me 250 out the door. it may be alot but that sure fixed my brake porblem. just incase someone may wanna know. if u have abs, it cost more for the cylinder.
MAC CAI
Flowmasters
HiFonics Amp (Subs)
XM Radio
Old 09-02-2004, 05:37 PM
fenderbender339 fenderbender339 is offline
Send a message via Yahoo to fenderbender339
Question Re: master cylinder
I am having the same problem, when i come to a stop ( hopefully ) , when i press on the pedal hard once the brakes lock ok, however, as soon as i release the pedal or presure of the breakes, the pedal goes all the way down to the floor, its geting worse.
a footnote: about a month ago my girl friend accedently put powersterring fluid in where the brack fluid should of gone. Can this be the result. if so how can i have the problem fix ? I also notice fluid dots of fluid on the garage floor just under the master cylander . any suggestion ?...
Old 09-02-2004, 06:34 PM
dfarres's Avatar
Re: brake troubles
you'll probably have to change out your master cylinder and you'll definately have to flush your brake lines and put fresh fluid in.
1993 Civic Coupe EX
Old 09-02-2004, 11:01 PM
accordztech accordztech is offline
Send a message via AIM to accordztech
Re: brake troubles
u paid too much for that master cylinder, those run about 100 bucks....
but any ways there is 2 bolts holding it to the wall, plus there is 2 holding the lines, try and not strip the 10mm bolts, and try to see if u can use a flare nut wrench to not mess up the bolts...
remove it, clean around and then put back in and bleed the brakes. u will have air in the system.
about an hour job.
www.cb7tuner.com <---90-93 accord board
:for sale: left and right motor mounts for 4th gen accord. great condition
:strut bar, rear..no brace...
Old 09-03-2004, 10:20 AM
AccordCodger AccordCodger is offline
Re: brake troubles
this WAS a 2-year old thread! He probably doesn't even have the car any more, let alone brake problems!
fenderbender339 - BAD news about the power steering fluid. That will eventually destroy all the rubber in your brake system. Flushing might buy you some time, but the wheel cylinders/calipers will give out before long.
Old 09-03-2004, 12:51 PM
Unhappy Re: Re: brake troubles
Thanks for ur replay, (if only my girlfriend/ an I worked as a pit crew tire changer for nascar on rusty team.) just one question, will i need to replace al cylinders/calipers on all four brakes including the rear or do u think it just might be the front two? Thanks
Old 09-03-2004, 01:01 PM
Re: brake troubles
It'll be all four - they're all contaminated with the same stuff.
weird brake trouble catfish Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 4 10-07-2003 08:07 AM
Brake trouble vik Accord/TSX/Accord Hybrid 2 05-08-2003 12:18 AM
brake troubles dfarres Engineering/ Technical 2 07-01-2002 07:57 PM
brake trouble beastfromeast Accord/TSX/Accord Hybrid 4 02-28-2002 10:48 AM
Brake trouble beastfromeast Engineering/ Technical 5 02-27-2002 08:28 PM
