Old 02-27-2006, 05:59 PM
DukeMan's Avatar
DukeMan DukeMan is offline
Weber carbs?
Hi,
where can I find fairly detailed IDA Weber carburators?
Sakatsu white metal ones (looks like low detail)?
Are there any model kits that include weber carburators?
Scratchbuilding a weber set-up for a V8 will be a bitch.
Maybe I´m not looking hard enough?
Thanks in advance!
/Fredrik
Current Projects:
-´70 Camaro Z28 (Baldwin Motion hood wanted!!!)
-´32 Ford Roadster (on hold)
´69 Camaro thread
Old 02-27-2006, 06:02 PM
freakray freakray is offline
AF Modelrater
Re: Weber carbs?
Get the Sakatsu set and start from there.
AF User Guidelines
Old 02-27-2006, 06:46 PM
CarModDave's Avatar
CarModDave CarModDave is offline
Re: Weber carbs?
Try these resin items:
http://www.bestresin.com/0500.htm
Scroll down to "Weber":
45mm IDA (std flange) 1/25th
48mm IDA (std flange) 1/24th
38mm IDA on Vee manifold (std flange) 1/25th
Not sure if these are what you are looking for but R&D Uniques carries 4 different intakes w/webers:
http://www.rndunique.com/rnd_productlist.cfm?pi=2&pc=11
HTH
Old 02-28-2006, 07:34 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Weber carbs?
The Tamiya Lotus 7 has a pair of well molded weber carbs. I don't know how much detail you're looking for but they certainly look the part. It's not hard to find the kit online for less than $10USD.
PHOTOBUCKET SUCKS
Old 02-28-2006, 10:23 AM
DukeMan's Avatar
Re: Weber carbs?
Thanks guys, that RnD unique setup look nice, bad pictures though.
I´m not looking for any superdetailed carburators, just something decent to start with. They´re going on a chevy small block, I´m going to add turned trumpets and throttle linkage.
/Fredrik
Current Projects:
´69 Camaro thread
Old 02-28-2006, 02:46 PM
proosen's Avatar
proosen proosen is offline
Re: Weber carbs?
If you want to cast some yourself I can put you up with some, at least I think they'll do?
Niclas
